Truck Stuck In Park
Discussion in '80-Series Tech' started by Parkair310, Apr 16, 2018.
  1. Parkair310
    Parkair310
    7
    Media:
    1
    Sep 28, 2016
    Estes Park, Colorado
    Hey guys, my 97 is stuck in park. I've checked the brake fuses which are good. Then the trailer wiring harness started to smoke right at the end. Is there any quick fix to the wires so I can get home? Nor do I feel like ripping apart my slee rear bumper. Any input would be great! Thanks!
  2. jonheld
    jonheld
    7,336
    2,161
    Dec 8, 2006
    New Jersey
    Pop off the small plastic plug on the shift console next to the "P" and stick a screwdriver down to release the shift lock.
    2fROOKIE likes this.
  3. Parkair310
    Parkair310
    7
    Media:
    1
    Sep 28, 2016
    Yes I know about the shift lock, but if the car is on the trailer wiring harness will continue to burn should I just wrap electrical tape around it and call it good?
  4. BILT4ME
    BILT4ME
    5,357
    Media:
    3
    Albums:
    2
    6,331
    Nov 9, 2012
    Olathe, KS, USA
    Remove the trailer harness from the main harness in the RR fender. The trailer harness has failed and needs to be replaced. Do this before your truck burns to the ground. It SHOULD be plug and play on both sides. The factory ones are known to fail like this over time.
    You can buy a replacement from eTrailer.com or just not install it unless you NEED it.
    Dave 2000 likes this.
  5. Parkair310
    Parkair310
    7
    Media:
    1
    Sep 28, 2016
    Am I able to get to the main harness from the inside?
  6. BILT4ME
    BILT4ME
    5,357
    Media:
    3
    Albums:
    2
    6,331
    Nov 9, 2012
    Olathe, KS, USA
    Yes.
    Drop the RR seat (3rd row) down or remove it.
    Remove the plastic cover and glove box cover on RR interior.
    Inside there, you will find a rectangular box about 3" x 4" velcro'd or glued to the inside of the fender. This is the harness you need to remove. Find the plug on both sides there, unplug the trailer harness out of it, then plug the two halves of the main harness together and should solve the problem.
  7. Parkair310
    Parkair310
    7
    Media:
    1
    Sep 28, 2016
    Sorry don't know exactly what I'm looking for. Real noob...
  8. Malleus
    Malleus
    2,250
    Media:
    30
    Albums:
    5
    1,286
    Jan 5, 2017
    Charlotte, North Carolina
    It's a black plastic box, the size of a cigarette pack. Mine is under the body, tucked into the corner of the frame.
    BILT4ME likes this.
  9. BILT4ME
    BILT4ME
    5,357
    Media:
    3
    Albums:
    2
    6,331
    Nov 9, 2012
    Olathe, KS, USA
    Mine was stuck to the black rectangular patch on the sidewall.
    Like @Malleus states, about the size of a cigarette package.
    I guess look under the truck on RR. See if it's under the fender or above the spare.
    Or maybe dig down inside the fender there to see if it's buried down below.
  10. midfat
    midfat
    840
    1,292
    Mar 25, 2013
    Santa Monica, CA
    Here’s what it looks like in mine...
    BILT4ME likes this.
  11. BILT4ME
    BILT4ME
    5,357
    Media:
    3
    Albums:
    2
    6,331
    Nov 9, 2012
    Olathe, KS, USA
    Do a search on the 80 forum for "trailer harness" and you'll see a number of threads on this subject. You can buy aftermarket harnesses. I looked for pics of it, but they mostly show the aftermarket version.
  12. gummycarbs
    gummycarbs
    1,025
    786
    Apr 14, 2016
    Oregon
    I think mine was taped up high. There's also a wire that is probably run under the carpet near the metal flashing below the tailgate. It connects to the left side, maybe the turn signal?
    Be sure to smash that thing to bits with a hammer while cursing port-installed accessories.
  13. inkpot
    inkpot SILVER Star
    12,920
    2,435
    Jan 30, 2003
    Chandler, Az.
    Most of this wiring is also visible/accessable thru the right rear tail light position. It is a bit easier to get a good view from there. BTDT!!
    BILT4ME likes this.
  14. MoJ
    MoJ Moderator
    3,620
    544
    Oct 24, 2003
    All else fails, start at the exterior plug and follow the wiring.
  15. 2fROOKIE
    2fROOKIE
    35
    Jan 7, 2005
    North Carolina
    Golf tee works well also :)
