Hey all, Long time lurker here mostly ..
Anyhow I have a 78 FJ40 that I am slowly resto modding, it has a stock 2F with header, Weber 32/36 carb and an HEI ignition. Runs pretty good ... now but i did go through an extended period of hair pulling recently.
The issue was that it would run great until about 2800 rpm then act like it was starving for fuel and just would not get past 60mph up hill. Soooo I spent a week tearing apart the carb and cleaning all jets, soaking the carb blowing out all the orifices. no help then I replaced all the fuel lines, and to further ad to the noise I had to replace the fuel pump recently because it was leaking oil on the ground and fuel into the oil, since I am going to go to TBI soon I chose an electric pump. again no help.
Next was ignition, I replaced main coil, spark plugs, wires and suspected the module .. replaced .. no help.
finally took apart the distributor to get at the pick up coil that is under the rotor, I think the NAPA echlin part # is MP104.. it fits a 1979 chev pick-up or Camaro that had HEI with a 6 Cyl .. Success! Seems the wires that go to the stator flex as the advance moves through the cycle and eventually break or the coil itself will suffer a failure from the vibration, at any rate this replacement fixed my beasty, and perhaps may help someone else with similar issue.
