- Thread starter
- #41
@OSS @ff347"won't turn over" = engine won't crank = dead battery or bad electrical connection at battery terminals. Even if the Engine fuse was blown, the starter should turn over the engine. If you don't even hear the starter click when turning the key to Start, I'd check the cables at the battery and whack the starter with something to maybe wake it up.
Does the horn work? Dome light?
Hey guys, thanks so much for getting back to me so quickly. My explanations weren’t very good.
I really was out in the middle of the boonies, super hot. Over 90 degrees at about 5500 elevation. The the fan actually was running, just didn’t check when I arrived to my destination. It was turning over but not starting.
I was able to get a text into Marshall and he said check the sight glass for fuel level.
It was super low. If I shook the rig back and forth I could see a little fuel in there, but it was really low. He then said to pull the gas cap and check for vacuum or pressure…
Sure enough I took the cap off and it was hissing and almost whistling so much pressure was built up. Let it sit another hour and turned the key and it fired right up.
Just got home. Check the sight glass and thr fuel level is still pretty low.
What can I do about that pressure build up?
Thanks again, glad I had cell service!
Photo attached is the sight glass just now when I got home.
