Can you make custom hoses too? Connecting a combo of chevy/toyota parts...
not personally no. but if you have the 2 dif hose ends i know a place to get them made for a very reasonable price.
I was told that Freeze12 was recycled R12. But you say it is 80% 134a? You are sure of that? then why is it so expensive?
are you an AC professional?
CruisinFJ60, I was replying to DoctorJJ.
thanks for setting us straight on freeze12 Doc.
I don't know how r12 could be better than 134a. In my Cruiser, with no changes other than charging it up with 134a, it will put out air at the register with temps in the upper 30's with almost any ambient temp and I've seen it as low as 35. I've been running 134a for about 50-60K miles.
my truck got down to 33*F at a 900rpm idle time was dusk and about 90-95*F ambient air temp while vehicle sitting still. thats with R134a
some vehicle dont respond well to R134a and others arnt bothered in the least.
im jut sayin.
I just came across this link How to Fix Your Car's Air Conditioner - wikiHow that mentions some A/C pumps need the right refrigerant otherwise it kills the oil and they die. I think this has happened to mine, as I had it swapped over from another truck and charged a while ago, and now after a bit of use the compressor wheel is very stiff and barely works...
I was thinking about the idea of refilling with propane after I work on mine, but didn't know that it was actually feasible. Sure it's an explosive gas, but hey I'm already carrying around a full 20lb cylinder of the stuff on my truck as it is, so what's the diff. Also, that way I would always have an emergency supply of propane!
you arnt changing much at all actually. thats a very common misconception. all you change is the drier to a new one and flush out the system. usually done with brake clean and compressed air.
Just replaced the compressor and the drier comes next. I'm going to have the system flushed once I have all new o-rings, get the new drier on and get the system tested for leaks.
btw, when I removed the drier, I shook it and could hear debris in there....most likely pieces of the impeller from the compressor.
Friday, I'll try again and see what happens.
I'm going with R-12 since I have some at hand.
Some (all?) dryers use silicone desiccant beads. They would rattle a little even if everything is good.
