Actually if you don't want to use bigger bolt on spacers, 10mm slip on spacers will clear the front hub and you use different center caps to get over the dust covers. With 10mm you still have enough hub exposed to center the wheels also. Rears don't need spacers and rock warriors offset is 50mm vs. stock wheels at 60mm so they will stick out 10mm more than stock aside from spacers also.
I’ve heard that these are the ones you want... PTR20-34071@Ali FJ80 What center caps work with the 10mm spacers? I can't seem to find any...
They are the ones referred to above. Came on the older tundra TRD wheels. It’s not an absolutely perfect fit from what I remember but it was pretty good.@Ali FJ80 What center caps work with the 10mm spacers? I can't seem to find any...
Are spacers a must? And is the 10mm slip on spacer the same design as the regular spacers (with lug nuts)? Appreciate the clarification
