Transmition problem...Eng. stalls immediately when put in 4L-R. All other positions work fine.
Also, eng. will not hold 650 rpm idle. intermitant. Cold eng. idl. speed OK. A/C on idle speed OK. ECU(?) senses low idle and will reset within 10 sec back to 650 rpm and all is well, smooth idle, no hesitation, apply brake and idle comes up slightly except in R-High. Drive around the block and idle will drop back down to 2-300 rpm.
No ECM fault codes
No TCM fault codes
Could these be related problems? Please ask more Q's.
1994 80 w/1FZ-FE and A442F trans
186,000 miles
Thank for any input, 4gotalot
PS can you tell I new at this...
No ECM fault codes
No TCM fault codes
186,000 miles
