Transmission Specialists in Seattle Area?
Seattle
Hi Everyone:
I'm pretty sure that one (or many) of the transmission seals have gone bad on my 93 FJ 80. After cranking up the engine for about 2-3 minutes transmission fluid begins leaking pretty heavily out of the weep holes in the bellhouse. However, dropping the transmission to get a look at the seals is definitely beyond my capabilities as a novice tinkerer.
Does anyone have any recommendations for a good mechanic and/or transmission specialists in the Seattle, WA area that I should consider for taking a look/replacing the seals.
Thanks in advance
if you already dropped the trans why not just put in the pump seal, its easy enough and maybe a 1/2:banana: after dropping the trans. just pop the seal out and inatall a new one, just put it in straight and tap around the seal so goes in evenly. you have nothing to loose and everything to gain by replacing the seal
Torfab.
Pay once, get it done right.
