I don’t have an answer to your question a year later, but I do have a question if you solved it.
I’m about to try and rebuild my transmission myself. Any tips or tricks, or any changes you wish you’d made?
Thanks
I can offer a couple of thoughts, that may help you.
» 1) Download the unit repair manual. And read it. And make notes.
» 2) Print the pages you will need for the operations you're doing. Do not take your manual into the workshop with you. ATF and paper do not mix well.
» 3) Make a chart, with the disassembly and assembly steps on it, and record everything you observe and all the measurements you make. As I said above, record all the assembly measurements PRIOR TO disassembly, so that you know what they were when you took the unit apart.
» 4) Lastly, use Toyota parts. If you buy an aftermarket "kit", you'll get parts for every transmission in the AW30-43LE series. None of them will be labeled and you will not know which parts you need. None of them will be OE quality, regardless of how they are advertised. If you rebuild a transmission with aftermarket parts and you get more than 5 years of service out of it, I'll be very surprised. OE parts last for 300,000 miles, at least. That's 25–30 years, for me.
You need a couple of transmission specific tools, and a couple of general use tools, which you may never use again. I'll post photos with links after this. Here's the list:
a) You need at least one (1) quart of kerosene, for cleaning. You can use brake clean, but it's far more expensive and doesn't clean any better.
b) Buy an aluminum pan, at least 2' x 4'. Nothing larger than 2 1/2' deep, because you can't reach any farther than than, but longer is OK.
– you'll use the pan for disassembling the case and the individual subassemblies. Do not use steel, and wood will just get covered in ATF which you won't be able to remove.
c) You will need some way to hold the transmission case, while you work on it. A dedicated holding fixture is the right tool, and one of the two (2) "special" tools you'll need.
– You will need to place the transmission upside down, horizontally, to remove the pan and valve body. You will also need to place the transmission vertically with the front up, to remove and install the internal components.
– You can use the pan for the horizontal disassembly and reassembly, and a plastic milk crate, upside down, will suffice for the vertical. You will need to create a hole in the center for the tail shaft, however you have to be able to reach the rear face for disassembly and reassembly.
d) I'd advise building, or buying, the second of two (2) "special" tools. You need some way to compress the spring sub–assemblies, in order to remove the snap rings and then to remove the pistons.
– There are many ways to do this, but you must have a special tool to do it. If you try to cheat, you'll ruin the spring assy and then you'll have to buy another.
– There are five (5) distinct spring assy's; replacing the four (4) that are still available will cost you over $100 wholesale. The 1st and Reverse spring assy isn't available and if you wreck that, you're screwed.
e) You need two (2) long flat screwdrivers, 1/4" or 3/8", at least 12" long. You'll use these to remove the snap rings in the lower (rear) end of the case.
f) You need at least one (1) and two (2) is better, long (at least 8") snap ring pliers; the kind with dimples on the ends are best.
g) There is a special 14–mm crow's foot wrench for the cooler loop union fittings on the case; Toyota buys them from KTC (this wrench is also needed for power steering gearbox work). A "standard" crow's foot will not work; it's too short. You may be able to use two (2) adjustable wrenches; I never have been able to make them work.
h) Lastly, you can use the pan as a wash tank. This accomplishes two things: One, you clean the pan really, really well, and Two, you don't need to buy a special, very clean tank to wash your parts in.
It goes without saying that you need to be organized. Lots of the parts you'll be working with look the same, and some even fit where they shouldn't.
When you disassemble the internals, do so while the case is vertical, front end up, and place every subassy you remove on your bench UPSIDE DOWN, the way you remove it. I work from left to right, removing the upper to lower subassy's, but any way you can keep everything separated and still organized is fine.
