Edit: I overhauled this thread for the sake of correctness. Thought I was seeing coolant, is either transmission fluid or oil. Still have a leak regardless. Was recently in the shop for a diagnostic on a bum radiator (plus oil change, general checkup) by a highly respected garage in SLC. Checked the transmission fluid while engine was running and it was good.
ORIGINAL:
Recently did a thorough flush while replacing hoses/thermostats/radiator and sprung a new leak. It looks like it's coming from the rear-bottom of the engine block, right in the middle between the two coolant release valves. I don't THINK it was leaking beforehand, but it is definitely leaking a lot more now! For what it's worth, it didn't leak during the first two test drives, did leak during the third and fourth, then didn't for the fifth. Go figure. First, what is leaking and, second, how many bananas? Thanks!
ORIGINAL:
