So i previously post a a thread with concerns about a possible tranny problem however i finally got to investigate the problem. (ACL surgery) As you can see there is a hole in the output shaft cover on the t case. So i take of the cover and the nut and washer fell out. Also the bearing had moved forward about 1/4in. So i dropped the tranny and tcase just to check everything out in case of any other issues. everything was ok and the grinding i was hearing was just those two gears sliding out and grinding cause the nut had become loose. Now putting things together and the output shaft nut only has a couple of thread. so maybe hopefully it is just the wrong size spacer, i measured it and it is just under 2 in. (1- 8/16) to be exact. Anyone know the correct size of this spacer? OR is this the right spacer and i have another issue. pics should help please let me know if you could help. By the way i have a four speed tranny (H41) with a three speed tcase and it is a 72 fj40, Thank you in advance
