Let me see if we have any 'for parts' actuators kicking around.
Your actuator looks pretty bad. Like it was submerged in water. Why not buy an Aisin actuator for $600 and use that as the motors, contacts, grease, etc will be new and in good condition?Hail Mary attempt here, I have not been able to find anyone who has found a replacement for just the micro limit switch. Does anyone have a supplier or pn for the micro limit switch?
Failing that, anyone have an old housing lying around they want to sell with a good limit switch? I'm trying to avoid a new or junkyard purchase of the whole actuator assy. Thanks.
Mathew
Thanks, that picture is a photo i grabbed from a forum. My motor had no rust or corrosion and the case was surprisingly clean for 280k miles. The switch contact points had some corrosion and in the process of cleaning, i broke the switchYour actuator looks pretty bad. Like it was submerged in water. Why not buy an Aisin actuator for $600 and use that as the motors, contacts, grease, etc will be new and in good condition?
I have an actuator in which the one thing which is not right is the switch. So the exact opposite of what you need.
Ah ok. Completely broken or just mangled the contacts? My switch isn’t broken but I messed up the contacts and it’s tough to get them to realign correctly. I eventually gave up. I do have my actuator but I kept it so I could bench test this winter and try to figure out why these fail. Depending on how fast you need the part I could send it to you, but I can’t guarantee it’ll work as expected… I had issues getting my actuator to work correctly after cleaning it and I suspect at least part of that is misaligned wires in that stupid switch. Also without the switch it’s harder for me to bench test but if I might be able to make your switch work for me enough for testing.Thanks, that picture is a photo i grabbed from a forum. My motor had no rust or corrosion and the case was surprisingly clean for 280k miles. The switch contact points had some corrosion and in the process of cleaning, i broke the switch
The rest of my parts look good and function well. Thanks again.
Well I was going to offer to measure mine but I just opened up the old actuator and the moving end of my switch is missing. WTF? I’m 100% sure it was there when I put my actuator back together like 3 or 4 times. I also noticed the screws were REALLY tight. Wondering if the dealer scavenged that switch off mine when they gave me the part back. Hmmm. So I can measure the switch housing but the plastic top is missing.I would imagine a generic limit switch could be used in place here. If we're lucky, it'll drop right in, but more than likely would need some minor rework to solder and epoxy in. Just need to find the right donor switch.
It's going to be an SPDT type. And we'll have to figure out if it's normally on or off (NC or NO).
If anyone can get a picture of the actuator with some caliper measurements, we could probably make that happen.
This one is probably not small enough?
Digikey has a bunch but need more measurements before looking at that catalog.
Rough photo, calipers are in the garage and it’s snowing…
The pins on the Toyota switch are on the ends, not the bottom.Rough eyeballing, but there's a chance the Amazon limit switch could fit?
There's some electronics guys on these boards. Maybe we'll get some of their expertise to locate a better form fit part?
Sorry to hear it's missing parts. I know the Tundra guys seek this too.
Yup. The tarnished half moon tracks on the wiper switches showed corrosion and pitting
Came by this video abou the same. Posting here for easy future reference.
I think that is what TeCKis300 did and started this thread about. Cleaning the area very good prior to opening up seems key.This looks to be a lot more simple than pulling the whole actuator off the rods/t-case…
I had no idea separating the actuator in half was possible- with the actuator still attached to the t-case. Anyone tried this method?
Some folks have been able to R&R these motors. Some have found they're in bad shape and need to replace the whole actuator. The beginning of this thread shows how to pull the external motors off and clean them up.Must have missed that, I thought most were removing the actuator- which makes me nervous- seems like this way you're less likely to get it wrong.
I do have to say, (knock on wood)- after replacing my battery and exercising 4LO and the diff lock- my flashing light hasn't returned....
Here’s another video of troubleshooting.This looks to be a lot more simple than pulling the whole actuator off the rods/t-case…
I have a spare sitting in my garage. I’ll find it and see if I can measure the micro-switch.I would imagine a generic limit switch could be used in place here. If we're lucky, it'll drop right in, but more than likely would need some minor rework to solder and epoxy in. Just need to find the right donor switch.
Well, I really dropped the ball on this one, now didn’t I?!I have a spare sitting in my garage. I’ll find it and see if I can measure the micro-switch.
I think I spent 8 hours once trying to triangulate Toyota suppliers who make submicro switches and who may list those for sale. I world have happily bought a few hundred of them to supply MUDfreinds, but no luck on finding. If someone has an electromechanical buddy, maybe this route can still be viable.Well, I really dropped the ball on this one, now didn’t I?!![]()
