Hi All, I have a groan/rumble when coasting at 55mph and higher. It’s worse when I’m out of gear. I suspected the transfer case, got under the car and pulled on the driveshaft…and immediately saw that there was play. Ha, that didn’t take long to diagnose. The output shaft that connects to the rear drive shaft has about 2 - 3mm of play. I guess that bearing is in pretty bad shape. I’m surprised it’s not making more noise and surprised it’s not leaking.
I did a search and didn’t find much in the forum. Are there any good writeups on the t-case rebuild? Any pointers from the group? I’m thinking I’ll get the kit from Cruiser Outfitters, but open to any leads on where to get the parts. Any good “while I’m in there” to do? The clutch is way overdue so I might do that and the rear main seal at the same time.
Thanks in advance for any help!
