Tranny to Transfer case bypass hose (1 Viewer)
12.75 is for NON split case like in a stock 78 fj40?
The 12.75 length hose is for stock 4 speed transmission and a one piece transfer case. To be sure it fits your drive train i would recommend you measure the distance from the center of the transfer case and transmission to make sure it fits.
1977 fj 40 4spd
P.M. sent 1977 pic. measured 13" so 12.75" should do the trick. Excellent work and thanks for your time.
Got my hose and found some time to get ur on... very nice job thanks again fits great.
the hose is a little stiff but can be moved if you wanted more room. clears beautifully. Got to add also even with a new seal, its a good protection to have anyway, not hurting anything, Great advice (from page 1) thank you...
I have one hose left. First paypal to me gets it. Pm me before you send a paypal to make sure it hasnt sold.
Sent a PM.
Sent from the islands.
Group buys all closed thanks for the support.
Thanks for doing this shipmag. Love my bypass hose!
Question for guys who have been running various bypass hoses for a longer time now: have your oil levels stayed even? Considering that the bypass hose will allow the pressure to equalize between the two units, I'm wondering if the oil will start to slowly follow gravity and leak back through the worn splines/damaged seal down into the t-case?
Here's a tech question I'm still pondering:
ok ill check in the next couple days! do you have to order 5 at a time? or can you order more?
I have a couple cruisers in my area and might just get a couple for xmas for these guys
$55! Put me down shipmag, let me know where to send payment as soon as you have em available.
From Austin Tx
