Thanks.
Is this an order item or can I get it in reg stores?
dont need more than simple 80W90 from VALVOLINE
this truck aint racin or pullin wheelies
so it dont need wheelie pullin trans oil
Redline Synthetic MT90
just so everyone knows, when using synthetic oil in the engine, you still should change it every 3K
what?? why??!!
even though the lubrication properties of the oil is still workin good, and thats why lot of guys run till 5K,
no oil is resistant to a gasoline engine's trait of asorbing acid.
when acid is absorbed, it breaks down the seals.
this is why it needs to be changed at 3K.
propane combustion is much cleaner thus resulting in less acid, so you can go 5K with out damage to the seals
syn oil cleans and removes deposits, and on an old engine combined with acid on those seals can allow it to leak more.
Don't discount the marketing factor for the car makers in this.... If car brand X says 7000 miles and Car brand Y says 3000, brand X may get people thinking of the long term savings, so now brand Y says 10,000.... and so on. It's no skin off their teeth, as it's pretty unlikely that it's going to cause increased warranty issues...
