Okay, apparently in the 8 years since I installed on the '08 my brain went to mush. I 'remembered' plugging the controller into the block but actually I would have removed the lead from the block and plugged the controller into the lead. All is well and functional. Just took the backbone to disassemble the dash, which I was lacking but is surprisingly easy.If you're '08 is anything like my '09 (and like the LC's above), which I suspect it is, the plug should be there. It is somewhat hidden at the bottom of the group. Plugged into a female bracket so it doesn't just move around. The picture posted above does show where it is pretty clearly. If you can take a pic, we might be able to tell you if it's really there or not.
Is there a chance that the previous owner (in you're not the original), left it hanging somewhere?
From the OP:
, job just due to the time it takes to find the dumb thingI appreciate the quick reply, ekberger. I was able to reach the connector by reaching up without removing the panel I mentioned. It was difficult but doable. Thanks again!
LOL I do not take my car to the dealer LX and LC are not common cars , so dealer are very poor when it come to electrical, yes you do have the plug in your LX it is well hidden and have a terminator plug that seems like it is connected to somewhere , you just have to remove the terminator plastic plug and that is it. I think by this time you probably found it.So I was able to access the plug on my '08 LC and when I replaced the LC with a '14 LX I thought I would be able to do the same. I got tired of trying to get enough of the panels off so I decided to have " my" Toyota dealer do it. They came back with the discovery that the LX doesn't have a plug! Of course I didn't believe them so I took it home and got off my butt and tore into it only to find that there is in fact no plug. So my question is, have they moved the plug? Do I have to pigtail it?
It will most definitely work. I did the exact install on my 2011 with the RedArc Towpro Elite. Just cut off about 4" of the pigtail end with the white connector and simply match the colors on the RedArc, solder, heatshrink and you're in business. Super simple. By the way, controller works flawlessly and is hands down the best controller i have ever had.Hey everyone,
I'm going to be installing a RedArc TowPro Elite this weekend into my 2017 200. The TwoPro only comes with pigtails off of the controller, they want you to procure a separate harness to connect to the truck. I went out and snagged a Tekonsha harness for a Tundra. I have yet to open the dash to start the install. Do you all know if that will work?
The Tekonsha PN is: 3017-S
On the harness I have, there is a separate white ground wire that hangs separately from the other 4 (which are bundled together). Where did you all connect the ground to?
