Trail Tailor Offerings- Racks, Sliders, Control Arms and Misc (4 Viewers)
Cool, just ordered. Not hurry in shipping, take your time!
Well.... Powder coater messed up a bit. But all good.
3 offerings in the soft shackle now..(WHILE SUPPLIES LAST)
1- BARE
2- RED
3- BLACK TEXTURE
@TRAIL TAILOR any more details on the UCA? I don't see them on the site
I'll have them back up on the website soon. I've made close to 200 sets over the past 8 years.
All parts are available to rebuild from local sources (including myself) I have close to 110,000 miles on the set on my 100 (lifted to 22.50" with my diff drop and sway links up front) (23.5" with my 1" body lift and true 35s -pictured)
3 Degree fixed caster correction
Currie machined joints - 2.5" OD full flex, no bind joints - rebuildable and greasable
1.25" 4130 CrMo wall tube arms
4130 CrMo ball joint cups
Greasable ball joints
CNC machined aluminum cover cap with o-ring
Completely assembled with BLACK MATTE TEXTURE powdercoating
**NOT THAT I DON'T MAKE THEM ANYMORE...... JUST AFTER MY STROKE; IT WAS A PART THAT TOOK A LOT OUT OF ME TO MAKE**
How much is the tire carrier i dont see it on the website. I didnt know this existed this could be an affordable option instead of a rear bumper.
Single arm starts at 1195.00
Message me for options
Jason
TT
Very cool to see a bolt on tire carrier option! I’m curious why the clamp on the swing arm is at an angle. Are you trying to put radial compression into the spindle?
I like these two bumpers with swing out ladder and spare tire carrier, can you share the pricing and specs like weight etc. I tried to check these in your website in the 100 series section but can’t find them. Thank you.
Bumper as pictured weighs approx. 250# Pricing is 3895.00 with LEDs and powdercoating. Shipping is approx. 440.00 to a business address.
I still use a 3 way LED, but they have a full clear lens instead of the multi-color now.
Jason
This is so customers can run up to a 35" tire and still operate the latch. In a straight vertical position the handle hits the tire and won't lock. If a dual arm is optioned; it is horizontally mounted and a no-issue.
Jason, are these rear bumpers tow-rated?
Many have asked if I will make a rear bumper that matches the design and high clearance of my 80 series Cruisin bumper. Started the bumper this morning and hope to have a finished product soon.
Rear crossmember does not need to be removed, but needs to be notched to accept the incorporated hitch receiver option. I will offer without the hitch cutout as well and keeps the rear crossmember whole for those that want that option.
Bottom of the bumper is attached directly to bottom of frame. So 3/16" below frame is the new ground clearance.
