Trail Tailor Offerings- Racks, Sliders, Control Arms and Misc (7 Viewers)
Just to clarify.....the antenna mounts have a mount for the antenna and also a hole for mounting a small cube light or something similar on each side, right? I'f so, I'll more than likely be ordering a pair. Thanks for making them!
Yes, each bracket has a 1/2" hole for an antenna and a slotted hole to put a cube LED.
J
1917213
Pair
I’d like a pair. Thanks Jason.
Almost got the body lift pucks and brackets etc.. where I want them. Waiting on a final price on a few hundred M10 bolts.
I'd like to offer a 1/2" and 1" BL kit.
12.7mm (1/2") 6061 CNC machined pucks and bolts
25.4mm (1") 6061 CNC machined pucks, CNC stainless radiator brackets, and bolts (may make a steering spacer as well, but looks like loosening the shaft coupler will let the shaft adjust appropriately into place)
J
Really excited about these! Do you have a ballpark on what the price will be?
J
Any preliminary idea on pricing?
GUYS CHIME IN IF YOU WANT PAIRS, PS or DS...
STAINLESS STEEL ONLY (Bare metal)---
Pair- 130.00
PS or DS 70.00
Thursday- Tuesday ---- antenna mounts and UCAs.
Cheers and thanks for the patience.
I'd like a pair
Right now pricing looks like:
1/2" ~~~ 140.00
1" ~~~ 185.00 (maybe a bit more if a steering spacer is required)
Jason
I’m curious why someone would want the 1/2” over the 1”? I thought the general consensus is that you need 1” to completely clear 35’s.
I don’t think that’s the consensus by any means. Depends on the exact size. I run a 315/75r16 and if I fully tucked my front wile turning it just barely catches the top of the fender arch. A 1/2” would more than do it. Maybe a 285/75r18 is different, or a 35x12.5r18. Those I can’t speak for.
1/2" BL will clear up to a 34.5" without the radiator and steering mods from what I've seen and experienced. True 35s and larger need more. Most don't/won't run over a 34.5", another rabbit hole with other issues.
I'd say 90% of all 100 guys are on 32-33.4" were there are no rubbing issues.
Other thing is the guys are moving to 18 and 25 offset wheels like me and need a little more as well. I'm on a 34.5 with 18mm offset wheels. I rub everywhere right now, even regular turning on DD travel. I still need to bend pinch welds and remold the inner fender covers too.
J
