@Espi SERE and
@ChuckB
I looked at my 05 and I believe the fairlead would come to this position, just below or right at the rounded edge of the bumper behind the license plate. the fairlead I used is the same width as a license plate.
The winch mount comes with two brackets for the two center lower bumper cover mounts. The mounts are slightly further rearward from the brackets that come on the mount. You would have to either put new holes in the bumper cover mounting plastic, this would be very easy to do as illustrated below or have
@TRAIL TAILOR weld the brackets back about an inch on the plate.
The bumper reinforcement on my 2005 is aluminum other then that it mounts the same as the steel reinforcement on my 1998. You'll have to cut out the center of the reinforcement and bolt the two outer pieces back on the frame like I did with the steel reinforcement on my 98. The outer brackets for the bumper cover left and right mounts are part of the aluminum reinforcement so they will transfer over wit the bumper ends.
I hope this helps you out. let me know if you have additional questions.
