Tracking down a noise on my 1HD-T / HDJ-80
Atlanta, Georgia
Ok folks, I’m getting a sound like a bad bearing somewhere. I’ve pulled all drive belts, and it continued. So I thought it might be the timing belt tensioner. Doesn’t get louder with the cover off. Could it be in the injection pump? Has anyone heard this annoying sound before?
I posted a short video of it on YouTube. This is with the drive belts removed, timing belt cover off.
Noise coming from the 1HD-T in my HDJ81 Land Cruiser - https://youtube.com/shorts/xxa8WbZTBdk
help/advice appreciated
Just want you to know I have watched the video 3 times. I am concerned about the noise and first and foremost I hope it is not the timing belt idler. That you can troubleshoot by removing the tension spring and turning. The video also ends as you approach the vacuum pump and I cannot tell if that is culprit. Test the idler and make sure it is not that first.
