Toyota SST 09992-00023 Compression Test Gauge Adapter substitute (1 Viewer)
Hi all...
If anyone has one of these that they are willing to rent or sell.... please get in touch. Cheers.
I'd loan you mine, but sent it to saltycoconuts to use and now he's MIA...
I too would love to use one of these... Anyone out there have one or have they all gone the way of 10mm sockets?
Hey mud, if anyone has one of these for rent or sale, please DM
If anyone has one of these they would like to sell - Let me know please :)
Otherwise i'll work on a solution and possibly do a group buy on a batch.
If you build one ill buy it
I'm also in need of one to buy or loan if any start circulating. Happily pay for a case of beer to rent it for a week or two!
Edited on May 25th, 2021 to add: I'm no longer making these compression test adapters.
I have been working on a compression test adapter for the 13B-T engine. This is a replacement/substitute for Toyota SST 09992-00023 Gauge Adapter. I have a final prototype in-hand now and am happy with the way it came out. So I plan to start selling them very soon.
This is an adapter that you would use with your own diesel engine compression test gauge. It comes tapped with either 1/8" NPT threads or 1/4" NPT threads for you to connect it to your tester's hose and quick connects. There's a Schrader valve in the cylinder end to ensure the adapter and gauge doesn't add any volume to the compression chamber.
These are CNC machined from steel bar stock. I have to run them in batches of 12 to be cost effective for materials and machine time. It takes about 34 minutes on the CNC lathe to completely finish a single part.
Accepting pre-orders on the first batch of 12 at $69/each just to get them out there. After that the price will go to $89.
Edited on Sept 9th 2014 to add: verified that this adapter works with the 12H-T engine as well.
Hi, I did see your edit from May 25, 2021 that you are no longer making these, but thought I would ask, just in case you had an extra kicking around you
to sell ? Thank You in advance :)
Darryl,
Vancouver
Canada
I asked @Radd Cruisers about this and he sent these photos of a modified Cummins tester that he also gave the specs to here in post #16.
If anyone was going to make one I’d love it if you could make two (or maybe more?). I was going to do this later this spring but I don’t have a welder so would have to farm out that step.
I’m pretty sure the dimensions of the 12HT injector and 13BT are the same for the purpose of making an adapter. Please correct me if I’m misquoting you @Radd Cruisers
“Made from a Case/Cummins 17mm injector adapter for compression testing.
Napa Listing:
Line Code ULT
Part Number 95003R12
Description Compression Tester Adapter
Make a plate the uses the two studs to hold the tester into place a per my image above. You also need the diesel gauge set - ULT 95003 which comes with some common adapters, or the more deluxe gauge set that has the above adapter included ULT 95004.
~John”
