Towing with a rear swing out
Albuquerque
I am towing with my 80 - Cummins swapped and have a 4x4 labs rear bumper , however with the rear swing outs the spare tire and the fuel tank storage get in the way and I can’t tow without a hitch extender - rated weight for the LC80 is 5000 lbs - tongue weight is 500max , however the hitch extender supposedly drops it in HALF! Is this really true ? I plan on towing a camper trailer that weighs 4,000 lbs . How can I get around this rear bumper thing ? Anyone had this issue ?
Not going to provide data, but yes, the hitch extender magnifies the tongue load significantly the longer it is. It will not change the load capacity, so a bit of a mixed bag. Try to clear the trailer tongue obstructions so you don’t need the extender.
Well that’s what I don’t want to do, otherwise it’s a waste for me to have a spare tire carrier , I have nowhere else to put my spare tire..
Here is what I’m dealing with - for my small trailers it’s fine but for my 4,000 lbs camper trailer with 300LBS tongue weight it’s a little more sketchy..
I'm running a long 2" receiver tube within the factory x-member that bolts onto my rear winch plate mount for extra leverage
For road trips, I have close to 400 lbs of gear hanging WAY back for swing out clearance and haven't had any issues
Even had my motorcycle back there and it's been solid (though I prefer to haul it with the minivan for easy loading)
In your case, I'd ditch the trailer jack for more clearance
I'm probably the last person you'd want towing advice from though lol
View attachment 4027342View attachment 4027345View attachment 4027346View attachment 4027354
I’m Thoroughly confused on how you have the hitch going into the homemade crossmember , anymore photos ? Is it removable ?
Ditch the jack, or rebuild it into a tauler jack, that way you can tuck the trailer in and tow normal and the tauler jack can both lift your trailer and your 80.Best of both worlds.
It's the factory X-member
I just cut a square between the pintle bolt holes for the receiver tube and welded it in, but the welding isn't really necessary as long as the tube tight within the hole
Did the same thing on a customer's rig and left it as a slip fit so he could remove it
Good idea also!
I suppose reinforcing my 4x4 labs bumper would work . I don’t think my bumper will move considering how it’s mounted but rather be safe than sorry
All you need to do is move the trailer jack on the pictured trailer, or swap it to one that folds down when hitched.
What’s in the way on the camper you want to pull?
The camper has the same style but it’s an electric jack , like the photo below .
My fix would just be putting the spare tire (and gas bottle?) in the camper while traveling. Keep it simple solution.
A hitch extender will significantly increase the forces on your hitch. Avoid one at all costs!
On my old camper, I added a plate to the front of the trailer, and relocated the trailer jack back about 12" to clear my swing outs. I also converted to an electric jack, since it didn't need as much space to operate.
-Rob
-Rob
That’s a good idea too!
