Torsion bar adjustment
Kampala
What is the size of the spanner/wrench for adjusting the torsion bar?
I believe 30mm socket to turn TBs if that is what you’re asking.
Yep, 30mm..
Be sure to follow the guides and raise your front off the ground and keep the droop right as well. Setting this droop right solved a problem for me after leveling up with the front stabilizer linked getting chewed up after just a couple of months.. If the droop is right this won't happen.
