Guys,
I need to place an order for several tools for upcoming service. I'll be replacing CV boots and repacking wheel bearings. I've misplaved a few tools since my last run in with CV boots. Can I get a run down on any specialty tools needed for the 100 series? Here's my current list:
large brass punch
54mm thin wall socket. (current 54mm socket is too thinck)
CV banding / cutting tool
wheel bearing poacking tool
seal puller
Also, I'll be ordering off amazon, so any recommendations on budget priced tools are appreciated.
Thanks,
Mark
I literally just did this. Haven't done the boots yet but I ordered pfran's boot clamps so that I didn't have to purchase a CV banding specialty tool. When you look at the list of owners he has sent them to, it is a who's who of the 100 forum. I figure they must be good...
On the cv boot replacement:
*i purchased a pitman arm puller after reading numerous threads on this forum.
*pfrans CV10 kit (as mentioned previously)
* 2 boot kits 04427-60120 list $40.00
On the bearing repack:
*duck billed snap ring pliers (as mentioned)
*brass punch to loosen cone washers.
*new gasket for flange 43422-60070 list $1.93
*54mm socket (bought mine off amazon as well OTC 6612 $26)
*new lock washer 90215-42025 list $2.64
*new seal 90311-70011 list $26.35
*various 12mm, 14mm 17mm sockets for misc removal of things
*I bought a 25# fish scale because you only need 6-10# and I thought the bigger the scale the less accurate it would be at the lower end. I may be crazy. I bought this one:
http://demandware.edgesuite.net/sit...apala/sku/25_lb_tube_scale_rmws-25.png?sw=525
*I watched this video and although I didn't do it exactly the way he did it, he uses vice grips on the cone washers to help persuade them out. It helped me.
Land Cruiser, Lexus front rotor and brake replacement tutorial - YouTube
If you need a seal puller... get one. You can do the same thing with a screw driver though.
I cut a piece of 2x4 about 4" long and seated my new seal with that and a deadblow hammer. The bearing race/seal drivers I looked at were not big enough to seat the inside race or seal. The bearing is about 3.5" and the biggest driver I saw available locally was 3.155". I am sure there are bigger ones available but get kind of cost prohibitive.
Since you are doing a repack, not new bearings, then you will not have to disturb the races. I did new bearings and races and used the 2x4 to start driving the new races in, then used the brass punch to slowly work them down into the seated position.
Good luck.
ps... I put list prices but I got them from Onur for considerably less. Also, part numbers are for a 2001 Toyota LC. I would guess they are all the same?
