Does a 2005 need to have the wheel bearings repacked for a front break job? I've heard that they do but an SAE certified toyota tech (independent) says they don't. He says they are "slip-ons" and later models don't need repacking.
Difference being, the Toyota mechanics are more likely to know what they're doing
I generally find this to be not the case.![]()
Well if you/he mean, by "front break job", replacing the rotor...then you'd better find a different mechanic because the one you quoted doesn't have a clue about 100-Series. Otherwise if he's referring to just replacing the pads then yes they are basically "slip-ons"...
Would that be the same for only turning the rotors? In other words need to be serviced.
So sounds like you don't need to have them repacked unless they need it or you can't turn rotors without taking them off. Any case, upon further questioning of my local dealership it sounds like out of (their) convience they remove the rotors to turn them because they only have one machine that will turn them while on the vehicle and it's "a tight fit" in the bay where they do them. Sounds a little scammy to me.
DOGMARLEY said:I only paid $507 at a local Lexus dealership for front brakes. That included labor and factory parts (pads, shim kit, fitting kit, fluid, etc.) That also included turning rotors while on truck. The tech said my bearings were fine and didnt need to be repacked at this time. They charged me $363 to do the rears. YES, I know thats expensive! I did a full brake job on my FJ62 including repacking bearings, new rotors, calipers, stainless steel lines and new hub kit. I bought the FJ62 to work on. I bought the LX470 for someone else to work on! They did want $400 for oil change, lube drivetrain, rotate tires, and change cabin filters...thats a little ridiculous. I paid $50 for oil change and did the filters and lubed drivetrain my self. Some things I refuse to pay for! I personally can't stand any vibration in the brake pedal...which may or may not happen with new pads on an unturned rotor. good luck.
