Hello All,
I did some repairs on my 1996 FJ80 (211K) yesterday and I'm having other problems that may or may not be associated.
History: The truck through a code after purchase telling me there was a flow issue with the EGR system. Passed emission ok so I just put it on the back burner. It also had an exhaust leak between cats. Other than that it runs and drives great.
Repairs: Yesterday I replaced the exhaust gasket, pulled EGR valve and module and cleaned with carb cleaner, did drive belts, front brakes. After I put the truck on the ground, started right up all is good. The next day driving home from work the heater stops blowing heat. My first thought was that I developed an air pocket somehow. Radiator was a little low, cap kind of spongy, so I filled it bought a new cap parked it on a hill and tried to burp the system. Heater control valve is open, hoses and tubes going into the firewall are hot but the exit pipes and hoses that return to the T stat housing are warm at best. Both rear heater and cab heater are still blowing cold.
The following morning, the temp is around 25 F and I have a rough idle at start up. I drive the kids to school and the first half mile was rough and the CEL starts blinking. It clears up and drive fine to the parts store where we pulled a number 6 misfire code. Fast forwards to last night, I start the truck and it bellows white smoke, rough idle which smooths out after the first half mile. The smoke smelled sweet so I fear the head gasket is giving up the fight. Any thoughts on the matter are greatly appreciated. I'm guessing my next step would be a leak down test to see if this is indeed the problem. Thank you in advance.
