Head Gasket shot. Committed
Still cant believe I snapped 2 HF extensions! ! I was hoping someone who has done an 80 head gasket would chime in with any tips we might of missed. The FSM seems to talk in tounges sometimes. I was looking for a picture of distributer set up post install after everything was lined back up. I'm probaly overthinking it as it seemed like any other head gasket job?? The 2 boards tip from bowfin really helped alot as its just an awkward weight and wierd angle to get head back to firewall without sliding.Thanks! I think if I would of changed my profile pic to some hot twenty something year old chick asking for help probaly would've gotten a better response. :rofl:
I am interested to see what people's thoughts are as how difficult this job is? It makes me very nervous reading all the problems everyone has with replacing this h/g. I have built an fj40 with ls, automatic, brakes, power steering and all new suspension but this scares me!
1st time for me. It’s helpful to gave a 2nd person. Do it in a garage and keep the hood off. Use Snap~On tools! Otherwise, not that bad. I’m nearly done. I’ve taken my time though.
It wasn't that bad. It was my first time doing anything as complex and I just followed the FSM and some of the advice I gathered here. If you have the space and the tools, it's totally doable.
Installed the valve cover gasket which goes on easily as long as you can figure out how to keep the rubber in the groove. Torqued valve cover bolts according to FSM. Installed the exhaust manifold along with gaskets. I bought new studs and installed but I don't have the correct OEM nuts yet. I'm going to see if I can get the top half of the intake manifold on today along with all the hard to reach nuts / bolts. Getting closer, will be glad when it's all done.
Does anybody know what the part number is for the nut that goes onto the exhaust manifold studs? All 13 of them. The stud is 90116-10169 but I don't have the correct part number for the nuts. Anyone?
Ordered the nuts and got them installed today. Began installing the EGR. Got the 1 1/4" and working on getting the studs into the intake. Thought they were E8 and they stripped. They're E7. Bought a new Snap-On E7 socket and have two brand new studs. Working on it again this evening.
Wow, who'da thunk! Excellent idea, why make it more difficult than it needs to be.
Using bolts allows you to get the egr valve pipe threaded onto the valve easily prior to any alignment efforts at the manifold.
Completed everything EGR, new heater control valve, all new hoses. Installed wires, installed distributor, connected 2 or 3 ground wires, almost forgot the rather large one from the wiring harness that connects under the lower intake manifold. Connected the starter. I'm getting closer to completion. Need some time of work to finish things up, working at night with minimal light isn't cutting it.
What torque value did you find? There has been debate on this. And WHERE did you find it?
No value in the fsm, found somewhere and had it written as 14 Ft.lb. Much tighter and I think the gasket might deform.
I'm surprised you didn't break them off or strip them at 14 Lb-Ft. I did strip two at that setting. I THINK it should be closer to 14 Lb-In.
FYI, the gasket does not compress further with the tighter bolts on the VC. The VC itself bottoms out against casting "bosses" on the head to the gasket does not over-compress. It's more like a lip-seal.
Plan for a video upon first start up. I really wish I would have. I got it after about 30 seconds but that first fire after that job was extremely satisfying. I would count it among the top feelings of my life because I realized at that moment that I was smart enough to take apart a complicated machine and put it back together. :)
That's a handy skill to have as it turns out.
Well, my first time starting it didn't go well.
Turned it over for the first time. Let it run for a few seconds then turned it off and repeated that four or five times. Let it sit for a little bit so that oil could flow.
No check engine lights. No codes. But after letting it run for about one minute or so it only achieved about 300 or 400 RPM. Have tried it several times since then, with the pedal to the floor it will start and hit about 450rpm, if I let off the gas it instantly dies out at 400rpm. Can't figure out what's not right here.
Bump BTT.
Following with interest as I will need to do this sooner or later. Thanks for the thread/pics. Good luck!
