So it turns out the stain that showed up a couple days ago on the first floor ceiling is from our toilet on the second floor.
Every time we flush, a few drops filter through.
Luckily, we did the testing with clean water in the bowl.
Because of the location of the stain, it's either the wax seal between the toilet and the drain, or maybe a leak in the PVC drain pipe as it descends to the main drain stack. I'm hoping for the former.
I've never changed the wax seal on a toilet before. Any advice? Is it as easy as disconnecting the water, unbolting from the floor, moving toilet, and dropping in a new seal (uh, after removing old seal, of course). Are there any "surprises" I should try to avoid?
What do I need? Just a new seal, some tools, and some gloves?
Every time we flush, a few drops filter through. Because of the location of the stain, it's either the wax seal between the toilet and the drain, or maybe a leak in the PVC drain pipe as it descends to the main drain stack. I'm hoping for the former.
