That would be great. What I need as far as I know now is a FF hub, both right and left axle shafts. But should I just go with chromo shafts?
Do they even make a FF 9 inch?
Yeah that would be great.I have everything Chris. I'm working locally on Monday in Brockton and could bring them by to you if you'd like
That's what I intend to do. Thanks.Prob a machine screw to replace one of those allens. If it were me I think I would take it to a rep. diff setup shop for inspection (Rick) and if all good replace the air line, clean the diff out really well, spray/clean out axle housing, repack wheel bearings, get some new axles, 1 hub, set of hub studs/cone washers/lock washers, hub gaskets, run some cheap diff oil for 100 miles and then replace. Wheel it. See what happens.
True but I like the ARB.You can always replace the arb with a spool
Waiting on parts....Chris- any progress on the repairs? Gary
