Fzj80 1997
I bought a built out low mileage 2014 for a smoking deal the other day knowing full well that it had a sunroof leak for a decent amount of time. What I did not know was that the 200 is not an 80 series in that a sunroof leak will absolutely **** s*** up.
Last night before bed, I was ignorantly looking into the best way to clean out the drains (they’re still clogged). I kept seeing threads and posts about how people were getting absolutely destroyed from water getting into the floor boards and seriously damaging the wiring harness on these trucks. I ended up not sleeping very much last night lol. First thing this morning, I ripped out the trim pieces to find absolute carnage on the lower connector. The other ones aren’t so bad, but the one closest to the floor board on the passenger side is completely roached. The driver side is perfectly OK which could be attributed to the kdss lean the truck is currently having resulting in the passenger side being lower.
My question for you all is, what should I do?
A. Replace the entire dash harness and passenger side body harness ~$4k in parts and a ridiculous amount of time and effort
B. Try to source the factory male and female pins and connectors and try to rebuild the harness in the affected areas. Not really a fan as the way this is set up is clearly an engineering flaw. The connectors should have been sealed.
C. Rebuild the harness in the affected area with Deutsch pins and connectors. Nice, well engineered pieces that are weatherproof.
I would really appreciate it if those that have dealt with the issue by going the non traditional route (no whole harness replacement) could help guide me through what you did or provide links that you followed to get it working right and reliably. A source for an electrical diagram would also be extremely helpful.
The carnage:
The carnage:
