To Turbo Intercool 1FZ-FE or not (1 Viewer)
Haslet, TX
Hello every one, this has been a lot of thinking and considerations to work out planning this.
1. ECU fuel control can stock ECU handle the turbo
2. What manifold / turbo combo to use
3. Intake air box and piping
4. exhaust system
5. Intercooler / plumbing to turbo
6. Transmission or clutch upgrades
7. Engine mods head gasket, head bolts, timing chain engine forged parts ect.
8. Fuel pump and possible e85
My rig is a 94 OBD1 ECU auto … not the best year to start with. I elected to super charge first as a let’s see how that goes.
Haltech ECU, e85 fuel sensor, dedicated IAT, Wide Band Haltech, coil over plug ignition, provisioned for Boost controller for when or if Turbo, hi flow injectors 980cc. Went piggy back ECU and it works, kept separate trans ECU and changed fuel pump and lines for E85 flex fuel. Performance noticeable improvement and better in cooler weather temps. IMO boosting beyond 5-6-7 psi you need to address IATs temps to help prevent spark knock in the engine. I elected to upgrade Knock
Sensors to less noisy versions , and make a dedicated shield cables to the knock sensors. I learned how to get a base sound levels on the knock sensors and set thresholds to detect knock.
Ran the truck 9 months or so and approaching 250k miles.
The ultimate upgrade would be turbo intercooled. With kit addressing the IATs the benefits IMO would be a huge amount. Unless cooler climate and perhaps hi elevations. In my 100 degree temps sea level area I wanted to work past the intercooling delima without having to be a designer and major fabricator. I searched out Australia PDI has a solution to mount an intercooler and relocate the trans oil cooler. However it’s for a diesel or 1FZ right hand drive trucks. Being no one else has ventured down this path with PDI intercooler with Left Hand Drive truck I felt I would be the 1st. I opted for 6 boost external boost controlled turbo, personal preference or cool factor and in my opinion better controlled boost targeting 15 psi up.
Ok, now 6boost creates another challenge, A/c suction line has to be re routed “ no big deal if you are changing the compressor anyways - and have the tools and I do” got swivel block fittings awaiting new line to make up.
Next dump pipe, the one provided from
HD auto the 02 bung and sweep is not totally correct for my setup. In the process of cut welded flange off , flip the pipe over. Shorter at the turbo connection and tack new collar on provided with the turbo. Ok, not a big deal. Next new 3 inch exhaust , stock exhaust IMO is two restrictive and need better flow. I went with stainless 3 inch Manta quite muffler diesel version. Cat isn’t required for my age truck where I live for its age. I am held up right now on the muffler for the exhaust. It mistakenly got left behind in Australia however it on its way.
I elected to do a grille back job. Replace all the rear heater piping, every coolant hose, new rear heater assy, and removed the trans and transfer cases to aid that.
When the engine was out hoping cylinders where not worn to bad, they were not but the combine piston and cylinder wear left lets bore the block. That lead to ok forged bottom end.
Don’t stop there, ARP studs, head , rods, Comectic head gasket their MLX better grade head gasket, new timing components Oe, new yota oil pump cover with pump, new valves and new valve springs.
The crank made standard with a polish and went back number 4 mains bearings, thrust OE and couldn’t find oe rod bearings. So clevite rod bearings. Time Machine work and parts for short block was done I pushed new Toyota short block cost.
Now some Custom machine work was done to my head and pistons was included in that price too. Maybe a 1000 bucks in my head machine work.
Ok, now got the engine together and why not, new crank balancer from Japan. Finally decided new valve cover and oil cooler too from Japan.
Just mocked up currently ….
To address the air box I went with 4 inch opening PISCO from Australia to upgrade that too. The brown on top is a protective coating and peels off. It’s clear looking through it.
Part 2,
The silicone connection hoses will have to be trimmed to fit but basic mock up looks good. Drivers left brake lines and os lines are kinda in the way. I replaced my ps pressure line and twisted it towards the center of the truck a touch, took the brake frame bracket off the frame and used 2 10mm unions to reconnect the brake lines and massage them not to rub on anything. Per the PDI instructions I was to loosen the frame attach bolt and push the top of the bracket back. However there is a steering box I was originally concerned about being left hand drive in the way. Removal of the bracket and two unions solved the issue.
The new US shipping my shipments are staged being sent because of value. The new valve cover / oil cooler are in the shipment that’s on hold. Dang it if I would have known I would have the 1st shipment sent over a week ago, Lessons learned.
The muffler coming from Australia is another issue awaiting its arrival to mock up the exhaust system cutting and spot welding it together to join the 3 inch system. An oversight my part and HD no pic list to check off items and not realizing no muffler.
It however is being shipped asap.
Once the exhaust is mocked up tacked up, I have it professionally welded. When the waste gate attachment is in place, remove the exhaust manifold and have it Coated. The manifold has to come Off for welding and oil cooler install.
Mentioned grille back, while transmission is out I obtained from Johnny at Cruisers and Company the nomad valve body for my transmission A442F and a guy in Australia has a device to add more throttle cable line pressure as manifold pressure changes from vacuum to boost. This should aid in increasing line pressure when needed since it’s mechanical. I have obtained new clutch’s and lip seals and will tear the transmission apart soon. I was wanting to finish the engine under the hood basicly 1st but I may have to change plans awaiting valve cover and oil cooler delay. With the nomad valve body and clutch piston mods hopefully the Transmission can handle the more power. This will be the most limiting factor in the project.
Last in line is the Transfer case. I am electing not to do the 10% underdrive like I did to my 100. Current size tires not cruisers turn same rpm’s at same speeds now. I can’t go 37-40 tires because of garage opening isn’t high enough and my 80 barely clears now. Both garages can’t accommodate much higher on the 80 or 100. So the plan is low range gears like
I did on my 100, and change output housing bearings and seals so when it goes other it’s done.
Lockers are next and have RCV 300 M axles and koyo bearings with eco seals for the front knuckles. That after getting it driving is next.
In the mean time Piggy back ECU, looking back having Been there done that. I would just rip the band aid off from the start. It’s work piggy back, but over all more complex in some
Ways. So, I am ditching my OE ECU, in December I moved the trans control to the Haltech and didn’t regret it. Kinda wished I did it all together. So what need is there for the Extra OE engine ECU, there isn’t. So not my preferred way, but a work around using Dedicated IAT and internal MAP, this freed up two wire circuits from Haltech to OE ECU, then by building my own shielded cable Knock Sensor harness that free up another two circuits Haltech to Oe ECU. I depinned the OE harness 6 wires labeled each one OE PIN number and type, moved the new needed circuits 1. Sensor ground for Coolant and TPS one circuit, 2. 5volt reference for tps , and 3. EFI relay control
To the existing pre wired circuits freed up. Then move the circuits at Haltech to corrected pins and labeled them.
Not ideal but workable… this allows me to ditch the Oe ECU now and be straight Haltech only.
The piggy back harness was from Boomslang and made it plug and play with fly leads for extras like Coil over plugs, IAT sensor, E85 sensor, boost controller… and plug directly into the wiring harness to the engine bay and OE ECU.
That solves Fuel control for boosting issues Haltech 2500 elite. With corresponding Boost controller, Wideband 02, e85, IAT, Boost control options plus 4-1 Haltech gauge.
Boomslang does nice work and can make harnesses for you. Grade A quality work. Looking back, I should have just had him make all to plug into my OE plugs. Lessons
Learned.
So wish me luck…
Part 3,
A delay has happened in Japan shipping my two parts to the USA. They went on holiday until May 7th and nothing getting send during now till then. So I imagine May15 maybe before my new valve cover and oil cooler will show up. Australia is shipping my muffler that got left behind.
So in the mean time switch gears and today scattered the transmission. I was very surprised just how good it looks inside. Very little material in pan, zero scorched clutches in the clutch packs. It was working perfectly before its removal.
I am looking into a clutch piston mod and adding extra discs to some clutch packs. This hopefully will help hold the extra engine power that is to come. Plus a modified Nomad valve body and line pressure actuator to help made increases like pressure as manifold pressure changes.
No oics today… will start case clean up tomorrow and washing hard parts
Tex
Looking good. Who’s the person who did the Haltech harness work? I would suggest insulating as much wiring as possible and probably the brake hardline and wiring down passenger side to axle. You planning on going coil on plug?
Boomslang did the harness about 14 months ago, and I mounted the Haltech over at the drivers side, ran fly leads out an already had a firewall penetration point clutch master is equipped hole to made connections to the e85 sensor, coil over plug harness connector right near the heater valve area, IAT in the intake “I drilled and tapped” and boost control when or if it got one. The main plug and play part across the instrument panel , I removed to the oe ECU. The harness follows OE harness under the instrument panel.
When I moved the transmission control into the Haltech in December I had again boomslang made the harness to plug directly into the oe trans connector. It had fly leads out to use to cutt and crimp pins on to mate into the Haltech main connectors. Not all circuits were used coming from the transmission connector. In order to have lock up trans converter activation I had to incorporate a relay to put power to the tcc solenoid and Haltech control the ground part of the relay.
Plus add a Haltech PHDL2 converter box to tell Haltech what gear the trans is selected.
I posted this on Mud the how I went about about makimg
It all work.
Coil over plug happened 12 months ago when I supercharged the truck initially. Needed Haltech back then.
Transmission going together. Got the case cleaned up
today after work, cleaned and resealed the Low / Reverse
Piston, and stacked the Reverse / Low clutch pack. I proceeded to verify the Piston travel when air checking the clutch. Set in the rear planetary and tail shaft, then the one way sprag clutch, finished up with the speed reluctor 18 tooth / parking gear. Installed the tail housing on with a new seal/ gasket.
Called it quits for today.
As the world turns, continues tomorrow.
Tex
Part 3 completed. Transmission with extra clutch discs in intermediate “2nd gear brake” and rear clutch “Direct” plus built up converter, with wholesale Nomad Valve body is completed. Got it installed back in the truck.
Part 4, Transfer case
Put it on the bench with the purpose of reseal extension housings and install low range gears.
Finished that today.
Part 5, get transfer case back in the truck and start installing new 3 inch in frame exhaust from Manta in Australia. It will have to modified to connect to the new turbo . Can’t wait to get this done. Ac hose line is planned for, intercooler or mocked up, just need the exhaust completed.
This is the next large hurdle to climb over.
Tex
Part 6
Lessons learned from piggy back to standalone.
On the 80 series OBD1 I am talking about the circuits needed to change are:
1. Sensor ground for TPS and Coolant they are the same and tied together.
2. 5 volt reference line to TPS
3. EFI relay trigger from ig switch in to OE ECU to power EFI relay from OE ECU out. I tied these circuits together after de pin the connectors. Aka removed this from the Haltech because Haltech is directly powered when the EFI RELAY closes and Haltech can't control it the way Yota does it. So had to tie the circuits together at the ECU harness to power the EFI relay when IG switch it turned on.
Tried to start truck, no trigge signal. Used Scoped via Haltech very weak trigger signal . Ahh piggy back just taps the highs and doesn’t carry the grounds.
4. Sensors in distributor Home and Speed grounds to Haltech Trigher sensor ground terminals fixed the weak signals and now triggers work.
Truck started! Wohoo!
Test driving revealed Electric Fans can’t keep up with temps no ac in 90 ish degree heat. I have a 4 row aluminum radiator and space to engine reduced. Tried supplied electric fans and no good. Went back OE shroud, OE Fan blade and blue clutch. Removed the orange new clutch because it’s hyper active to my application. I bought it when needed it for spacing for the supercharger trial.
Can report perfect temps on Blue clutch and oe shroud.
Without AC so far.
Awaiting Reduced Barrier Ac hose to arrive to make my new hose. I ordered incorrect hose Ac barrier hose and does not fit my fittings.
The OD of the number 10 size hose is diferant.
Trans working as espected fine tuning the spring tension to aid throttle pressure under boost / vacuume.
Working out grille now to fit.
Intercooling YES! What a difference that makes! Have only 5 lbs spring in waste gate now as I break the engine in. What a performance difference between Turbo intercooled vers supercharged, wow!
Heat soak at Starbucks coffee time, 150 degrees IAT , take off 1 block 130, 1 mile 115-120 at 45 mph. Yes! Intercooling works!
I Highly recommend that! Numbers do not lie lower IATs is more dense air.
Engine power is great, the stall in the converter as you roll in the gas hit the sweet spot of the turbo. Spools fast and responsive.
70-85 blip the throttle and it’s there. With no down shifting depending on how aggressive torque converter unlocks.
I could not be happier.
My cruise works too… with full Haltech Standalone
My new instrument cluster and mount due any day.
UB-10 Haltech
Someone here on the forum has done this to his Taco.
Trans is behaving perfectly so far !
Take care
Tex
