You will need both the top and bottom retainers on each bushing. I installed a similar shock without the lower upper retainer once and the shack was pulled through the mounting opening. You can likely reuse the OEM retainers as they are almost always the same size. Check your fitment though.
I called the vender and got phone voice mail 4 hours ago and counting.I would call the vendor you purchased them from and confirm. I would think it is better to have the metal retainers surrounding the bushings on either side of the shock mount. OME shocks have four metal retainers.
Was yours similar with large and stepped cushion (bushing) like these?You will need both the top and bottom retainers on each bushing. I installed a similar shock without the lower upper retainer once and the shack was pulled through the mounting opening. You can likely reuse the OEM retainers as they are almost always the same size. Check your fitment though.
Yours came through, were they large and stepped or more like OEM --soft?Glad I'm not the only one that's done that! :whoops:
Sounds reasonable Woody. They are hard and doubtful they'll mash down like the OEM cushion (bushings) But the three post before you seem to disagree, is troubling.For the aftermarket shocks, it's washer - bushing - mount - bushing - washer...per your photo above.
I believe OEM bushings are not "stepped" to fit into the mount eye on the frame, and thus need the additional washer to keep them centered.
like I was and recycling OEM or something similar in frustration.You will need both the top and bottom retainers on each bushing. I installed a similar shock without the lower upper retainer once and the shack was pulled through the mounting opening. You can likely reuse the OEM retainers as they are almost always the same size. Check your fitment though.
OME is one of the few aftermarkets...
I'll hang-on to my old shocks as they are still good after 150,000 miles & 13 yrs (WOW), as back-up. If the bushing do slip I'll use the old retainers, I kind of like that idea. But for now, just using the aftermarket intended set-up Woody suggested seem fine.x2, many shocks (including OEM, Old Man Emu and others) use this setup. However, your bushings look to have an alignment 'step' built into them? I'd personally prefer the washer as the lip of the bushing could tear/wear and slide thus letting your shaft smack the mount but it's likely a non-issue? If the bushing sits nicely inside the OE washers, I'd re-use them.
Hey Matt, I've only had the fronts on for the day, ~20 miles around town/HYW. I can feel a very slight improvement over my OEMs. Braking, cornering, dips and bumps all felt good, but so did my old OEM shocks. The ride is slightly stiffer and I feel the road (small bumps) just a little bit more than I did. I suspect the real test would be off road for these bad boys.
Over the last year or so; I've notice a slight drifting on HWY which is part of the reason I installed these. They didn't make any noticeable difference in drifting, but was just opportunity to start a complete RR of suspension I'm just now starting. My goal is to get back as close to show room fresh dive as possible over next year or so.
Hope to see you again and hear more about why you have those supportive lic plates.
_______________
I will, thanks blue...
Strange that the OEM shocks only have this on the front. On the rear, it is metal on either side of the lower bushing, but metal only on the top of the upper bushing, according to the parts diagram anyway. I am replacing my Fox shocks with OEM, and went to do the rears last night, and could only find 3 of the retainers for the rears. Thinking there should be 4, I swiped one off of the front shocks. Looked up parts diagram to order replacements, and only 3 shown on the rear, though I swear the FSM showed four... Glad I had kept them, and the Fox shocks are the retainer, bushing, bushing, retainer setup like these TJM's. Will have a complete set of Fox 2.0's with only 6 months on them FS next week...You will need both the top and bottom retainers on each bushing. I installed a similar shock without the lower upper retainer once and the shack was pulled through the mounting opening. You can likely reuse the OEM retainers as they are almost always the same size. Check your fitment though.
