Tire Pressure recommendation (1 Viewer)
If you are asking about an LT-Metric LT285/75R17 121S Load Range E tire, then the RCTIP for that tire on your LC200 is 35psi F/R.
HTH
Indeed I was, many thanks!
@gaijin I searched and could not find for this tire, could you please provide RCTIP on my 2014 Land Cruiser? Looks like 35 psi on same size and load rating from other manufacturers previously posted but wasn’t sure if manufacturer matters…thanks!
TOYO OPEN COUNTRY A/T III LT285/75R17 121S E1 BSW
Manufacturer and Load Range don't matter.
The RCTIP for ALL LT285/75R17 tires on your 2014 LC200 is 37psi F/R.
The RCTIP for ALL LT285/75R17 tires on an LX570 would be 35psi, but not for the LC200.
HTH
Thanks for the help in advance @gainjin. May I get the RCTIP for BFG AT T/A K02 T285/65R18 125/122R Load Range E on LC200 HE wheels?
Looking for pressure recommendation for 2010 lx570 with P275/65/18 Yokohama geolander a/t
Assuming you are putting those LC200 HE wheels on a LC200...
The RCTIP for those LT285/65R18 tires on your LC200 is 42psi F/R.
HTH
The RCTIP for P275/65R18 tires on your LX570 is 28psi F/R.
HTH
Thanks I a m currently running 32 psi cold. Should I expect to see a Mpg decrease running at 28 psi ?
Probably not noticeable, but your choice.
Always glad to help ☸
The Recommended Cold Tire Inflation Pressure for the LT295/70R18E 129/126R Falken Wildpeak A/T3W tires on your LC200 is 35psi F/R.
HTH
Can you tell me the RCTIP for this tire on a 2017 LX?
Sure!
The RCTIP for LT295/70R18E 129/126R Falken Wildpeak A/T3W tires on your 2017 LX570 is 35psi F/R.
Note: 35psi is the minimum allowable RCTIP for LT-Metric tires. At this minimum, this tire has sufficient Load Limit of 2295 lbs to be suitable for use on either the LC200 or LX570 at the same 35psi.
HTH
Seeking a recommendation. 2018 LC, 2" OME lift, SPC uppers. Wheels are 17x7.5, tires are Yokohama Geolander M/T LT285 75-17. TIA
Hard to imagine that after 1355 posts, we haven't covered every possible tire and 200 series combination.
What's the largest I can fit without lifting?
Will a 285/65R18 KO2 rub?
Does it dry up like a raisin in the sun?
Just to be clear:
The RCTIP for LT285/75R17 tires on a LC200 is 37psi F/R.
HTH
I mean.... not to put any self rightous gurus out of a job but:
