Tire Pressure recommendation (1 Viewer)
The recommended Cold Tire Inflation Pressure for the Cooper Discoverer S/T MAXX LT295/70R18 129\126Q tires on your 2013 LC200 is 35psi Front/Rear.
HTH
I'll start with 35.
And that install sheet is wrong. The correct Recommended Cold Tire INflation Pressure for LT285/70R17 tires on a LC200 is 40psi F/R.
Here is a link to the original install sheet: Original TRD 17" Install Sheet
Please note on page 5 of 12 the recommended cold tire inflation pressure is 40psi F/R.
Toyota later determined that since the TPMS sensors will not trigger a low pressure warning until the set pressure had decreased by 25%, this recommended inflation pressure could allow the tires to run at 30psi before a TPMS warning which might be interpreted as a violation of FMVSS (Federal Motor Vehicle Safety Standards) which require a minimum allowable inflation pressure of 35psi for LT-Metric tires.
To avoid potential fines and possible litigation, Toyota changed the recommended cold tire inflation pressure to 46psi. Here is a link to the revised install sheet that reflects this change on page 5 of 12: Revised TRD 17" Install Sheet
This revised pressure of 46psi results in a TPMS low warning trigger pressure of 35psi which is consistent with FMVSS minimum requirement of 35psi.
Thus, 46psi is not a "correct" pressure, it is a "CYA" pressure.
Run whatever you want. Believe whatever source you want. But 40psi is the pressure that yields the performance designed into the LC200.
HTH
G- thanks for the explanation! (Off to adjust my tires)
@gaijin any chance for a RCTIP on the Nitto Ridge Grappler 285/70/r17 116Q ?
Yes, sir!
The RCTIP for the Nitto Ridge Grappler ISO-Metric (Reinforced) 285/70R17 116Q tires on your 2013 LC200 is 38psi F/R.
HTH
Hey @gaijin do you happen to have a pressure for a Nitto Ridge Grappler in a 285/75/18 on a 200?
No, I don't.
But I do have a pressure for the LT285/75R18E 129/126Q tires.
Since the Nitto Ridge Grapplers come in both ISO-Metric (e.g. 285/60R18) and LT-Metric (e.g. LT285/60R18) sizes, I had to go to the Nitto Tire web site (Nitto Tires) to see if a "285/75/18" Ridge Grappler even exists - it does not. So I assume you meant the LT-Metric size LT285/75R18.
The RCTIP for the LT285/75R18 Nitto Ridge Grappler tires on your LC200 is 40psi F/R.
HTH
Hmm I might want to increase my 129 duty lt275/80r18 up then. . . Been running at 37.
No, I don't.
HTH
Apologies for the lack of specificity, but you nailed it. The LT is the tire I just put on, so I appreciate the help! 40 is definitely higher than I would have run so I'm glad I checked with the guru.
You should contact the manufacturer and ask them what cold inflation pressure is required to support a load limit of 2,105 lbs.
That tire size does not appear in any of my reference materials.
HTH
Gaijin,
How about LT285/70R-17 BFG KO2 E Load Range on 17' x 8' wheels on a LC200?
Thank you very much.
The RCTIP for the LT285/70R17E BFG KO2 tires on your LC200 is 40psi F/R.
HTH
Gaijin,
RCTIP for LT285/70R17 Falken Wildpeak AT3W Load Range C on 17" Rock Warrior.
TIA
Gaijin,
TIA
Second verse, same as the first...
The RCTIP for ALL LT285/70R17 tires on a LC200 (I assume this is what you have, not an LX570) is 40psi F/R - same as in my sig.
HTH
@gaijin sorry I tried to do the calculation on my own but couldn’t get it! I have 285/65/18 k02s on a 2018
I appreciate it in advance!
Let me guess... you don't really have 285/65/18 KO2's, because they are not made in that size. I'll guess you have LT285/65R18/E 125/122R KO2's, right?
Guessing again that you have a LC200 and not an LX570, right?
If my guesses are correct (I'm feeling lucky!), the RCTIP for the LT285/65R18 KO2's on your LC200 is 42psi F/R.
HTH
HTH
You are correct! Thank you!
Sorry for the late hijack. Looking for proper inflation pressure for a stock 2011 LC200 running LT285/65R18 Ridge Grapplers. Can’t seem to find it in the search.
I really appreciate it!!!
