Tire Pressure recommendation (13 Viewers)
Master Gaijin,
How about Yokohama Geolander G105 285 50 R20 112H for 2015 LX570?
Master Gaijin,
Sure!
The Recommended Cold Tire Inflation Pressure for the 285/50R20 112H SL Yokohama Geolandar A/T G015 tires on your LX570 is 39psi F/R.
HTH
Gaijin,
How about tire pressures for 285/65/18 Yokohama Geolandar A/T G015, Yokohoma doesn;t make the LT version in this size.
Thank you very much.
Gaijin,
Well, something doesn't add up.
The only Yokohama Geolandar A/T G015 tire I see in that size is the LT285/65R18 125S Load Range E. In fact, Yokohama only makes the LT-Metric version in this size.
Please check your tire size again and let me know.
Also please confirm whether this is for a LC200 or LX570.
HTH
HTH
My tire size is 285/65/18 and it for a LC200. Appreciate the help.
Please advise the tire make, model and Load Index.
TIA
Here you go -
Size 285/65R18 125S
Load Range E
Vehicle 2013 LC200
That's still incorrect, :bang: but I'll assume you mean LT285/65R18 since that is the only size Yokohama offers for the Geolandar A/T G015 125S Load Range E.
Anyway...
The Recommended Cold Tire Inflation Pressure for the LT285/65R18E 125S Yokohama Geolandar A/T G015 on your 2013 LC200 is 42psi F/R.
HTH
Anyway...
HTH
Thanks a lot
Another request if you would please and thank you.
2010 LX570
Falken Wildpeak ATW
LT285/55/R20
Thanks, Brad
2010 LX570
Falken Wildpeak ATW
LT285/55/R20
Thanks, Brad
Glad to help and you're welcome!
The Recommended Cold Tire Inflation Pressure for the LT285/55R20E 122/119T Falken Wildpeak A/T3W tires on your LX570 is 43psi F/R.
HTH
Wow, the tire shop I had install them has the tires at 34 cold. Thanks again for you help. Brad
Hi @gaijin thanks so much for helping out with this! Pretty awesome.
I’d like the recommended pressure for:
LX570
Toyo Open Country AT II Xtreme
285/55/20
122/119S
LX570
285/55/20
122/119S
Glad to help, but I need you to confirm your tire size.
Toyo makes the Open Country A/T II in both P285/55R20 and LT285/55R20 (no ISO-Metric 285/55R20).
The Recommended Cold Tire Inflation Pressure is different for the P-Metric version and the LT-Metric version.
Which version do you have?
If you have the LT285/55R20 then:
The Recommended Cold Tire Inflation Pressure for the LT285/55R20E 122/119S Toyo Open Country A/T II tires on your LX570 is 43psi F/R.
HTH
HTH
You guessed correctly. I have the LT285/55R20E.
Thanks!
2008 LC 200 - HTR SPORT H/P - SIZE: 285/60R18
Thanks!
The Recommended Cold Tire Inflation Pressure for the 285/60R18 116H SL Sumitomo HTR Sport H/P tires on your 2008 LC200 is 33psi F/R.
HTH
How about the Blizzak LT 275/65r20 on my ‘18 LX?
Thanks!!!
Sure!
The Recommended Cold Tire Inflation Pressure for the Blizzak LT275/65R20 126R Load Range E tires on your 2018 LX570 is 36psi F/R.
HTH
