Tire Pressure recommendation
Master Gaijin,
How about Yokohama Geolander G105 285 50 R20 112H for 2015 LX570?
Master Gaijin,
Sure!
The Recommended Cold Tire Inflation Pressure for the 285/50R20 112H SL Yokohama Geolandar A/T G015 tires on your LX570 is 39psi F/R.
HTH
Gaijin,
How about tire pressures for 285/65/18 Yokohama Geolandar A/T G015, Yokohoma doesn;t make the LT version in this size.
Thank you very much.
Gaijin,
Well, something doesn't add up.
The only Yokohama Geolandar A/T G015 tire I see in that size is the LT285/65R18 125S Load Range E. In fact, Yokohama only makes the LT-Metric version in this size.
Please check your tire size again and let me know.
Also please confirm whether this is for a LC200 or LX570.
HTH
HTH
My tire size is 285/65/18 and it for a LC200. Appreciate the help.
Please advise the tire make, model and Load Index.
TIA
Here you go -
Size 285/65R18 125S
Load Range E
Vehicle 2013 LC200
That's still incorrect, :bang: but I'll assume you mean LT285/65R18 since that is the only size Yokohama offers for the Geolandar A/T G015 125S Load Range E.
Anyway...
The Recommended Cold Tire Inflation Pressure for the LT285/65R18E 125S Yokohama Geolandar A/T G015 on your 2013 LC200 is 42psi F/R.
HTH
Anyway...
HTH
Thanks a lot
Another request if you would please and thank you.
2010 LX570
Falken Wildpeak ATW
LT285/55/R20
Thanks, Brad
Glad to help and you're welcome!
The Recommended Cold Tire Inflation Pressure for the LT285/55R20E 122/119T Falken Wildpeak A/T3W tires on your LX570 is 43psi F/R.
HTH
Hi @gaijin thanks so much for helping out with this! Pretty awesome.
I’d like the recommended pressure for:
LX570
Toyo Open Country AT II Xtreme
285/55/20
122/119S
LX570
285/55/20
122/119S
Glad to help, but I need you to confirm your tire size.
Toyo makes the Open Country A/T II in both P285/55R20 and LT285/55R20 (no ISO-Metric 285/55R20).
The Recommended Cold Tire Inflation Pressure is different for the P-Metric version and the LT-Metric version.
Which version do you have?
If you have the LT285/55R20 then:
The Recommended Cold Tire Inflation Pressure for the LT285/55R20E 122/119S Toyo Open Country A/T II tires on your LX570 is 43psi F/R.
HTH
HTH
You guessed correctly. I have the LT285/55R20E.
Thanks!
2008 LC 200 - HTR SPORT H/P - SIZE: 285/60R18
Thanks!
The Recommended Cold Tire Inflation Pressure for the 285/60R18 116H SL Sumitomo HTR Sport H/P tires on your 2008 LC200 is 33psi F/R.
HTH
How about the Blizzak LT 275/65r20 on my ‘18 LX?
Thanks!!!
Sure!
The Recommended Cold Tire Inflation Pressure for the Blizzak LT275/65R20 126R Load Range E tires on your 2018 LX570 is 36psi F/R.
HTH
