32cls6speedmt
which brand of mobile one, are you using?
One concrete difference is the timing chains vs belt, and that system sure seems to run quieter on the 5w-30.Consistency across all my platforms. 2UZ has lived on 5W30 worldwide wither (higher) so far mileage lives than the 3UR. With no material change in bearing clearances internally, I see no reason to run a 0W30 on the 3UR.
Not "every" market but yes the general statement is correct.Seems like I read somewhere that in every other market, Toyota recommends 5w-30 and that the only reason for 0w-20 in the US was something about emotions or MPG? Did I imagine that?
Yes that was me.Seems like I read somewhere that in every other market, Toyota recommends 5w-30 and that the only reason for 0w-20 in the US was something about emotions or MPG? Did I imagine that?
Yeah, don't buy a reman engine. There's a place called GTR auto that all the Hemi guys buy nearly new motors from for $4-5k. They offer a reman Tundra 5.7L for $6500 but I would not recommend you buy that. $5k is on the very low end.to find a 5.7L engine in Canada, you're looking at used 300k kms+ engines for that price.I should say. All work was done at Lexus dealer. When bearing failed was coasting down the highway under almost no load. Had changed oil 500km before with fresh 5w30 mobil 1. We stopped the engine and had it towed to dealer.
I figured it would be timing something. It wasn’t
they pulled vavle
Covers and looked at timing. All marks were good and chains tight. We pulled filter. It was very full of sparkles. Pulled oil pans. Same thing. Metal flakes, chunks and sparkles.
peered into bottom end. Could see #7 con rod very
Loose on crank….. pretty sad after putting 4K into timing stuff.
engine has 230k km in it. Not abused since I’ve owned st 130k km.
totally bummed out. Now what?
engines are about 5k here to buy. That’s a tundra engine as no 570 units around. Truck is work 25k running. Almost nothing now….
No knock at all before it really started.Yeah, don't buy a reman engine. There's a place called GTR auto that all the Hemi guys buy nearly new motors from for $4-5k. They offer a reman Tundra 5.7L for $6500 but I would not recommend you buy that. $5k is on the very low end.to find a 5.7L engine in Canada, you're looking at used 300k kms+ engines for that price.
To get a lower mileage 3ur-fe in Canada would be at least $8-10k. What were the details on the engine you got quoted for $5k?
Tundra long block list price from Toyota Canada is $29k.
Your motor didn't knock for a while before it went bad?
I had similar noises from my 2011 Land Cruiser. To me it sounded like the clutch on the A/C was going out because it was the same noise when my A/C clutch went out on my old F150. I bought a new Denso A/C compressor and clutch from Rock Auto and it fixed the occasional bolt in a can rattle. I still had a little valve noise clatter on cold acceleration going up hill: was told it might be the VVT valve having varnished or gunked up. Bought Sea Foam high mileage ran for 300 miles (followed directions) before oil change. I also went to 0-30 oil. Engine runs much quieter, accelerates better, and gets better mileage. I'm going to use Sea Foam before the next oil change too. Engine has 151,000.
What if I suggested it was the 30W oil and Seafoam had nothing to do with it…….I had similar noises from my 2011 Land Cruiser. To me it sounded like the clutch on the A/C was going out because it was the same noise when my A/C clutch went out on my old F150. I bought a new Denso A/C compressor and clutch from Rock Auto and it fixed the occasional bolt in a can rattle. I still had a little valve noise clatter on cold acceleration going up hill: was told it might be the VVT valve having varnished or gunked up. Bought Sea Foam high mileage ran for 300 miles (followed directions) before oil change. I also went to 0-30 oil. Engine runs much quieter, accelerates better, and gets better mileage. I'm going to use Sea Foam before the next oil change too. Engine has 151,000.
Yeah, Seafoam scares me - I don't like adding anything to the fuel tank except...well, fuel.
the valve noise went away before the oil change: while doing sea foam treatment. No Sea Foam in fuel it was in the crankcase one ounce per quart for 300 miles. Valve noise started getting less after about 100 miles and continued to subside until oil change at 300 miles of city driving. The bolt in can noise rattle went away and has not come back after A/C compressor and clutch replacement they were done about 1 month before Sea Foam treatment. I'm not an additive fan, but it seems to have helped. The can says it's for VVT and internal tensioners. My noise's started about 123,000 chased the intermittent clanging noise for 20 months. It seemed if I played with the A/C switch it would stop. That's what prompted the A/C work. Techron in the fuel works on the fuel system and some internal carbon deposits. There are lots of moving parts with very small tolerances and a crankcase cleaner that has been around for a long time seemed like a good gamble. May not be the answer to your noises, but it seems to have fixed mine.What if I suggested it was the 30W oil and Seafoam had nothing to do with it…….
