how much time does it take to put a borescope though the plug holes and look inside to see if something is mangled up there, for one thing?
I have a scope I bought at Home Depot fairly decent one, the problem is though I would think is you would only be able to see the piston head unless there was significant scaring you would't be able to see anything. You would need a special scope with a camera facing the scope shaft to inspect the valves. Anyway I do not disagree that it would of been worth the effort at least trying. Taking the head off would be the best way to actually be certain.
all it takes is an angled mirror you put on the end of the scope head to see the valves...
Not sure how far you want to go to save your uncle some cash, there is a mud user selling a drive train and engine in AL. Truck rolled but he said truck is mechanically intact.
See here: For Sale: - 1999 land cruiser 4.7l v8 conversion alabama
If it was me, I would replace the entire engine with either a low millage or a well maintained one. In the end it will probably be a cheaper fix and you have the opportunity to do all the proper maintenance before dropping it it very easily. I've never liked messing with machining heads and valves on two bank engines, seems like things could go wrong if not done by an expert. You may end up paying more if something is not done right. Dropping in an engine can be done by most people with out a whole lot of precision skills. 2 cents.
I appreciate that input. Im guessing we would probably need to go with an 06+ because of the VVT and electronic throttle control being compatible with the ECU.
Wikipedia lists these vehicles as having the updated 2UZ:
Another 2UZ-FE variation adds VVT-i and electronic throttle control.
Applications:[6]
So if we go the used engine route, would one out of any of these vehicles work fine?
- 2005–2009 Lexus GX 470
- 2006–2007 Lexus LX 470
- 2005–2009 Toyota 4Runner
- 2006–2011 Toyota Land Cruiser
- 2005–2009 Toyota Tundra
- 2005–2009 Toyota Sequoia
(EDIT: obviously we didnt get the 2UZ in the LC 200 in the US.)
EDIT AGAIN: I may be getting ahead of myself here, should probably be sure they have opened it up a little to see what damage was actually caused before spending any time going down this road.
Just spoke to the tech up there, I think he may be a service advisor actually. Apparently they tried cranking it again, and it actually ran for a few seconds he said but made a bunch of bad noises. Says they are sure there is piston damage. He is making his suggestions before thy have pulled the heads and based on the fact that they will not machine heads, that the last one they did "cost them $20k". If they pull the heads they want to put new ones on, priced at $1115 each. I asked him how much to pull the heads, he's calling me back on that one. Sounds to me like a dealership just trying to cover themselves, while making the most money for the least amount of work at the same time. A win-win-win for them!
By the way, anyone know how many labor hours they should charge to pull heads? My toyo guy who used to be a dealer tech told me about 2. He also said a motor swap should be 17. Lexus is quoting me 27+++ for that.
