Builds time to start over
Glowshift true wide band set up arrived today, hopefully the matching oil pressure gauge rolls up soon
Looks like great progress is being made
The panhard rod wont brake in a hurry and although the links look a lot stronger than factory ones they are also designed to be the weak link in the system should something need to give
Ordered some superior fixed length lower and adjustable upper rear arms last night, going to be 1 tough rear end
So today i had the car run on a local dyno to see how much power the snorkel was robbing from me. Absolutely shocked but stoked at the reaults as now i know why ots down on power. time for a 4 inch stainless snorkel.
So today i had the car run on a local dyno to see how much power the snorkel was robbing from me. Absolutely shocked but stoked at the reaults as now i know why ots down on power. time for a 4 inch stainless snorkel.l
~16.3% loss. Way more than I would've expected!
Ye i was a pretty supprised i expected 10hp at the most
Yeah, that's approx the loss expected through the entire drivetrain. I would've expected it to be about even (cooler air vs longer distance) but I suppose they're designed solely to raise intake and probably little research is done on how internal turbulence/airflow rates are impacted by their shape.
Personally, I'd be curious to hook up the computer see AFM readings with and without the snorkel to see the difference.
