I was tired of the floppy stick shift lever in my runner, so I tore it apart to see if I could tighten it up. If you remove the tower, you will see a 16mm ball at the end of the shift lever. That ball goes into a metal collar that rides on top of the shift rails inside the transmission. The hole in that collar is just of 3/4 inch, so I threw a steel bushing in there that measures 5/8 by 3/4 by 1/2. The shifter is now tighter than a drum, and seems to be holding up nicely!
The bushing actually is loose inside the collar, but I think if it were any tighter it would probably bind.
Rock on...
Rock on...
