Tierod and Draglink end size??
I am currently searching, but thought I would post up since there doesn't seem to be a thread about this specifically.
Can anyone verify the size of the threads on an FJ60/62 tierod and drag link? Are they the same as the FJ80 ends everyone uses on highsteer applications?
I know that (at least some of) the ends are physically different from the FJ80 rod ends, but I would like to know if the FJ80 ends and the 60/62 ends have the same size threaded shank and thread pitch. Any help you can give would be appreciated.
Thanks.
from what I understand you shouldn't even have to ream the 60 arms….the 80 series arms should fit i believe
oh- I thought ( from other posts) that the 80 taper was bigger?
t
Not sure about the 80 series taper, but for 60/62 series the drag link end taper is larger than that of the tie rod ends'.
What's your goal with using 80 series components?
