My what a big pedal you have……
Looks great.
Get that. Looks awesome
Fingers crossed the hood closes!
Fingers crossed the weight of that chain against that plastic intake didn't fubar it. They are sensitive creatures.
I'm liking the motor mount solution. Hopefully it dampens the vibrations better than the OG AA setup I have (which vibrates pretty bad).
Yeah I was nervous about that but so far after checking everything looks good. If it’s cracked, I guess it’s a good excuse to swap to a Ls6 intake and fuel rail I guess. I took off the fuel rail for that very reason.
I am hoping the same on the mounts. My original mounts were poly, so these rubber mounts will hopefully be much softer. Once my trans mount gets in I’m planning on getting the crossmember burned in and get driveshafts ordered. Wondering if I can run LC ujoints on the front with a thin tube to clear the trans pan. Those small spicer ujoints don’t look too promising
Pto?A pto drive shaft on the front is about the only option to clear the trans
Pto?
