Got the Heater hoses all mocked up and cut. tucked in along the injector rail. Hope i have room back there to turn the injectors backwards and tuck the wiring harness when it comes time for wiring. Need to write down the amount of clamps i need so i can order some stainless hose clamps with the liners in them. Need to flush out the Toyota red from my heater so i can run the GM orange stuff and throw the clamps on and the cooling system is done. Im wondering if i can use toyota red or pink in the Vortec motor
Nice and low profile
Radiator hoses mocked up too. Cut the lower one about 3/16 inch too short but it will still work
Ordered up a metric crap load of AN fittings for the Trans lines and fuel lines. Hopefully this week i'll get the fuel system mocked up and measure what i need for Fuel line and fuel will be all done.
Once the shroud arrives i can knock off pretty quickly:
-AC System, need condenser in place to build brackets for PS and Trans coolers, mount the dryer, then will have local dude come do my AC hoses
- PS System,
@FJ60Cam PS hose kit is installed, just need to install the cooler and PS is done
- Trans lines, running one AN trans line under the fan shroud to the cooler in the driver side of the radiator, then to the external cooler, then another AN line back into the system on the passenger side.
-Fuel, Mount tank to fuel pump filter, fuel pump, high pressure fuel filter, then AN line to the AN6 fitting i have on the fuel rail. OEM regulator on the fuel rail is going to be used, and return line is already installed.
-Ordered a Vaccuum hose for a firstgen camaro with a 90* molded into it to run off of the brake booster and to the back of the V8. I made a fitting using an old steel line from the 2f mated to the push lock vaccuum connector on the V8 with a 90* bend in it. This will make a clean vaccuum line with no kinks
Hoping i can get all this done in the next few weeks, then it will be down to Trans/Tcase shifters, Airbox, wiring, and PCM tune. Will be using OEM 1980s era toyota Cruise control, will post pictures when its done. Its going to be freaking awesome. Going to be period correct on the inside of the truck.
Trying to get some Driveshafts ordered from Reel Driveline via @woody 's recommendation this week. Doing Fj60 ujoints with a 2 inch thickwall tube in the front and FJ60 stuff in the back with thickwall tube in the back. Really hoping the output flanges from the FJ60 diffs swap over to the Fzj80 axles in the future. If not thats going to suck.
