Long-winded reply warning:
It seems like there are a lot of things that can make the throttle sticky. Maybe yours is different but I had this issue off and on for years and did not figure it out until I had my carb rebuilt by Marlin.
The hanger on the carb for the throttle return spring was bent, not a lot, but enough. Probably like that when I got it, and the throttle would stick like you described every so often. I did all kinds of s*** to fix it (not realizing the hanger was slightly bent), including lubing the linkage, replacing all the springs, and even shortening the long shaft on the linkage. None of it really worked.
I pulled the carb (for other reasons) and shipped it to Marlin, and when it came back the hanger was even more bent. Not his fault - it was packed well but FedEx really threw the box around and that hanger is really vulnerable.
ANYWAY… I re installed the carb and ran it like this and it really stuck, right from the get go. Finally noticed the bend and once I straightened it out (should be plumb and level on it’s two planes), the problem went away, never to return.
PS: I also made sure the return spring at the carb was the actual OEM spring. I think this matters. It’s NLA but I got a used one from Cruiserparts for $10.
Pictures would help a lot. I’ll add some when I get a minute.
Adding some pics for
@FishTown:
Here's a nice clean rebuilt carb with a bent spring hanger, courtesy of Fedex. Yeah I should have noticed but that hanger was bent when I got the truck in 2010, so it never really occurred to me. If you have your carb off and it's moving around the garage, and especially if you ever ship it, this gets bent really easily.
Here's the OEM return spring that attaches there:
CruiserParts Accelerator Wire Return Tension Spring [90506-12034-U] - Listed for 80-83 40 Series and 80-87 60 Series Land Cruisers. This is no longer available New. If you have any questions about the item(s) that you may need please feel free to call and we will be glad to help you find what...
shop.cruiserparts.net
