- Thread starter
- #21
Doesn't look bad to me, but then I live in New England. This is what we're used to:
http://i.imgur.com/bM65Grz.jpg
Holy moly!!! Yeah, I guess the undercarriage on this ‘14 doesn’t look so bad after all.
Again my only real concern would be the KDSS valves. If you can turn them at all with a 5mm Hex wrench then you’re fine, just slather then with marine grease whenever you get the oil changed. If you can’t open them however it can be costly to fix. You definitely need to open them for any suspension work, not just adding a lift but for front strut replacement and other repairs, so make sure they’re working or the dealer replaces it
Aside from that most of the rust will come off with a wire brush and some effort. Paint what’s there once you’re done and apply a coating of fluid film every fall and I’d consider it ok
I would pass. Tow hooks look badly rusted and the kdss bar is the most rusted I've ever seen. All those little 10mm and 12mm fasteners are horrible to remove (easily snap) if they're rusted, which they all are.
Did someone say rust? This was a 2008 from Whitefish, MT, a supposed non-rustbelt state.
If the KDSS doesn't work, is that covered under the CPO warranty? I assume I could pull it into the garage, spend a day with a wire brush and go crazy underneath. I have read about this stuff called Corroseal that is a rust converter/primer. Then I could either paint the underneath with rustoleum or apply fluid film/Krown.
The new coating is not too bad to break loose tbh. It’s the rust on the threads that’s the biggest PITAYou can coat and neutralize what's visible. The problem is all the fasenters. Forever you'll be fighting frozen hardware. Not to mention KDSS.
