vtcruiser60
- Joined
- Sep 23, 2003
- Messages
- 2,570
PSC has a solution for fabricating your own tie rod/drag links and the solution has caught my attention. What are your thoughts?
They offer a thick steel tab, chamfered at the base and designed to be welded to a 1.5 inch tubular draglink. The tab is designed to carry a Heim rod end, and I suspect designed to connect the pitman to the draglink through a tie rod. Here is a link for more information:(BK-TR01) Heim Joint Tie Rod / Drag link Adapter [BK-TR01] - $36.00 : PSC Motorsports, Off-Road Steering Experts
I would like to build my own tie rods and drag links, and incorporate a set of new FJ80 TRE that I have on my shelf.
The adapter seems to offer another solution to those not running high steer (double steering arms) or cross over steering. I don't see any influence on ackerman angles as the steering arms are not impacted.
But I have never seen HEIMs used for steering linkages and only heard that they are not so good over time on the road. I am also a bit leary of an untested product....especially over something as important as steering.
So...thoughts?
So...thoughts?
