For Sale This cruiser is in Billings, Montana
Year
1967
  1. 40 Series
Nice 1967 Land Cruiser FJ40 32K
Nice paint job, all metal work on tub completed. Has a mix of years of cruisers, later model Tub with early doors and top but includes flip out windows on the side of the hardtop. Nice upholstery on all seats and even has the original rubber mat for the floors. Late model windshield with wipers low on the windshield. All lights and signals work as well as the gauges. Goo
d running 2F engine with new gaskets and seals, including the rear main and front-end seal and pan gasket. EGR working correctly, nicely tuned Webber carburetor. Has the electronic ignition. It has a new clutch including resurfaced flywheel and new clutch and pressure plate, pilot bearing and throw out bearing. It has new brakes all around including a new master cylinder rebuilt calipers and resurfaced drums in the rear. The transmission received a new input seal as well, the transfer case was rebuilt with new bearings and seals. The park brake was rebuilt with new shoes and hardware. The front axle had the knuckles rebuilt and new wheel bearings, the hubs were cleaned and reassembled and a new pinion seal installed. The rear axle had new axle bearings and seals and a new pinion seal installed. This is a very nice cruiser, ready for years of enjoyment.
Contact larry Brewster larry05@bresnan.net selling it for a friend get ahold of me and I'll answer all questions.
Nice 1976 Land Cruiser FJ40
Nice paint job, all metal work on tub completed. Has a mix of years of cruisers, later model Tub with early doors and top but includes flip out windows on the side of the hardtop. Nice upholstery on all seats and even has the original rubber mat for the floors. Late model windshield with wipers low on the windshield. All lights and signals work as well as the gauges. Good running 2F engine with new gaskets and seals, including the rear main and front-end seal and pan gasket. EGR working correctly, nicely tuned Webber carburetor. Has the electronic ignition. It has a new clutch including resurfaced flywheel and new clutch and pressure plate, pilot bearing and throw out bearing. It has new brakes all around including a new master cylinder rebuilt calipers and resurfaced drums in the rear. The transmission received a new input seal as well, the transfer case was rebuilt with new bearings and seals. The park brake was rebuilt with new shoes and hardware. The front axle had the knuckles rebuilt and new wheel bearings, the hubs were cleaned and reassembled and a new pinion seal installed. The rear axle had new axle bearings and seals and a new pinion seal installed. This is a very nice cruiser, ready for years of enjoyment.
What's the asking price?
Bottom door gap looks even but it looks like the door does not match up with the top (GAP top left corner). More pictures will for sure help with interest.
cruiser is a mix of years so there are a few fitment problems. I'll try to get some more pic's
Did you delete the 1st pics (profile from the drivers side) that show the ill-fitting doors/top?
