- Thread starter
- #41
While I'm waiting on engine parts, I figured I might as well get some other stuff done to the truck.
One of the first things I wanted to do was upgrade the sound system, so I bought a pair of Rockford Fosgate 6.5" speakers on Amazon. When they came in, I opened the door and realized I have a 5 speaker truck, and there aren't speakers in the front doors. Luckily there's a speaker hole in the door, and only the interior door panel will have to be cut. I removed the panel and tried test fitting the speaker, but the magnet just barely came in contact with the window slide.
After doing some brief research, I bought some MDF and started making some spacers. I usually only work with steel, so I didn't have a lot of woodworking stuff. After outlining the design, I cut MANY straight lines with a reciprocating saw, and then rounded everything out with an angle grinder. They fit great, and all I have to do now is pull some wire through the doors and screw everything together.
They came out fairly consistant, and are exactly what I needed, all for around $5 bucks.
