Builds The Trail Snail Build | Above Average Overlandish (6 Viewers)
SmokingRocks
hopelessly addicted to Cruisers
Colorado
In 2014 I bought this unlocked 1993 FZJ-80 from a fellow enthusiast up in Frisco with 155k on the clock, check out the thread below to see how it has transformed into what it is today!
Then 9-10-2014
Now 3-6-2022​
Suspension
FrontRear
Layout3-linkHi-Steer4-LinkSPC LCA's, D&D adjustable UCA's
ShockDobinson IMS 45-6091210.8" StrokeDobinson GS 59-68710.7" Stroke
SpringTJM XGS 4"TJM XGS 4"
Drivetrain
Engine1 FZ-FERebuilt top to bottom Sept 2016, with snorkel, Blue fan clutch advanced with 10k Oil
Trans.A442F
X CaseHF2AV3.11:1 Crawler Gear, VC removed, 7 pin mod, Viscus Coupler removed
AxlesNitro Gear 4.88'sARB Air Lockers, Front & Rear
Drive ShaftFront Double CardanNorthern Colorado Driveline
Tires & Rims
Toyo Open Country MT's315/75 R16 (34.5")
American Heritage16x8.5 0 offset
Exterior
Interior
Electrical Systems
Starting Battery | FrontDual Purpose Marine AGM X2Power Group 27F SLI27FAGMDP | 90 Amp Hour
House Battery | FrontCrown Deep Cycle Group 27M SLI27D27XD | 95 Amp Hour
House Battery Bank | Rear(3) RoyPow LiFePO4 S1218 | Combined 54 amp hr (650 Watt hour)
Solar Panels2 x 100 Watt Panels wired in parallel
Rear Bank Charge Controller & IsolatorRenogy DCC30s DC-DC 30 Amp Dual Input (Alternator & MPPT Solar) Charge Controller
Rear Fuse Block Low Voltage Cut-OffBlueSea 7600 Adjustable Isolator
Stereo Head UnitKenwood DDX775BH
SpeakersPioneer TS-G1645R
SubwooferBazooka 8" BTA8100FHC
AmplifierPioneer GM-A4604
RefrigeratorDometic Max Burton 53qt
FreezerDometic Max Burton 37qt
Inverter1100 Watt, Power Bright PW1100-12 modified sine wave
NavigationiPad Mini 4
Ram Mount
Dual Electronics XGPS150A | Bluetooth GPS Module
My Garage / Shop (the Trail Snails R&R spa)
Spring 2022
Cabin Air Filter Mod
CDL Actuator Repair (Self Inflicted)
VACATION Moab
Cree Bar and 5lb Extinguisher and my ARB switches
Here is a pict of the stock low beams
Here is a pict of low beams + LED Bar
Below is with the seat all the way forward, there is no interference between them. Also there is still tons of passenger legroom.
ARB Switches, the Heater switch was relocated under the ignition switch.
how did you mount the iightbar? just curious.
The Cree bar came with Cast Aluminum brackets, I ground down the mounts to make the feet a bit angled to match the cab. Then ran a carriage bolt through the roof to the inside of the cab. Flat side is inside, bolt is outside. Everything is siliconed.
35" Mud terrains are going on order this week! also going to start fabing a front pumpkin saver and my skids. Trying to get ready for the Rubicon in August!
Did you mount that rear lightbar to the "wing" inserts? If so you absolutly must give the model of lightbar, brackets, pictures, and any measurements. Very slick mod
Looks good. Not sure if personally I'd mount the light bars by drilling through the roof though.
Thanks guys for the input. Heres a couple things, first of all I am at 7500ft in elevation so with 33's and stock gears I can barely cruise at 70mph on flat ground in 4th. Any incline and it bounces back and forth between 3rd and 4th so I'm thinking a regear is a must. Talking with the guy I bought the truck from (who lives at 10,000ft in Frisco) he said that he didn't notice enough of a diff between stock and 4.88's, so thats why I was thinking of 5.29's.
Secondly, I guess my scope is to make this more of a rock monster than an overland rig. We are planning an august Rubicon trip and I want to be pretty set for that. Also I will be adding tons of weight to this thing in the form of more armor and an interior roll-cage (hopefully by august) further necessitating a re-gear.
Finally about the light bar: Its a Cree 42" don't know the part number I got the front curved 50" and the rear on a group buy at trundatalk.net for a "to my door price" of $230. While they aren't RIGID's they are fantastic. My 80 didn't have a rear wing so I drilled through, used a carriage bolt (flat side on the inside) a judicious amount of silicone and the supplied rubber spacer to install both bars. I am 99% sure that the holes will not allow moisture in and the bars are very stable. @Dubbinchris Why would you not drill the roof?
@DavidinAZ is that on 35's?
Since I'm at sea level and street drive most of the time I am happy with stock and for the most part no issues what so ever doing easier expedition style stuff. But since you want to do dusy and rubi then that's a whole different ballgame/expedition. That's more like dedicated rock crawlers and regear is needed plus your elevation. INFACT I think most people trailer in their rigs to dusy. And I heard 37 is kinda small for dusy now and days.
I would suggest changing your O2 sensor also and then check out marlin crawler gear. With the crawler gear you should be able to have 4.88 for highway driving and have even lower gearing than 5.26 alone, best of both world IMHO. Eventually i will drop that in so I have low gearing for the dirt and rubber OD for the streets.
Thanks @Qball If I do Rubi this year I will most definitely be trailering it there. I'm looking at fuel cost and don't know if Rubi is feasible this year, might have to settle for Moab and mt. Blanca this year.
35's is as big as I want to go. So you are suggesting 4.88's? I figure what I lack in wheel size I will make up for with armor so I can drag myself over obstacles if needed.
Whats the reason for changing the O2 sensor?
You may want to rethink the interior roll cage in terms of passenger safety issues.
In a street-driven vehicle where passengers typically do not wear helmets, a rollcage may actually present more of a danger to vehicle inhabitants. Forces on passengers in an accident at highway speed are quite different from those exerted when the vehicle rolls while rockcrawling at relatively slow speed.
I've put one in my K5 many years ago after seeing how soft the A-pillar is on that vehicle, but the 80's cabin structure may not need this?
Great looking vehicle to the OP but I agree with Chase on this one. I've seen a lot of internal roll cages that just seem really dangerous if ever in a real accident. You don't want your head hitting that cage for sure.
Plus, I've seen a number of rollovers posted in the forum and these 80s hold up really well at speed.. can't comment on trail rollovers but one would assume...
I've thought about this and have been in one roll over in an 80. It was a full revolution, and while we were fine I wouldn't want to see what a two revolution roll over would look like. Not to mention there are some scary areas on the trails here where the fall would be 3-4 revolutions on rocks, I wouldn't want to be without a cage in these instances.
I can't imagine rolling over several times on the pavement at highway speed is much different than 3-4 revolutions on rocks.
ehhh.... I can
Pavement is nice and flat, rocks are jagged and nonuniform. That could collapse pillars way faster than a flat surface. Not to mention you are usually rolling down a hill when you f'up off road vs a flat road.
Some in my club have had to pick up pieces of skull from an unfortunate Xj owner after he rolled 3 times off of Jaws 2 on the mt. blanca trail. Had he had a roll cage it may have been different.
I will say that I wouldn't want to be in a multiple rollover in either scenario.
