The official part number request thread (19 Viewers)
Should I have a rubber seal across the top of my 2016 grill? Anyone have a part number?
yes you should.
53039-60040
I believe this applies to all post-facelift US LCs. 16-21
Includes all of the little clips that snap into the holes to retain it.
I can't tell from your picture but are there already foam rubber strips on the tops of the headlamps?
Also for the record, if you throw your model and year into your signature on here it makes it a bit easier for people to provide assistance.
yes you should.
53039-60040
Yes, I do have seals across the top of the headlights. Thanks for your help!
My 2015 seems to have a blacked-out grille. It's starting to bubble, but I can only find the chrome grille. Can anyone help with this? Thanks!
It looks like someone painted your OEM grille - no such "blacked out" grille is available from Toyota.
I suggest your three options would be:
1. Re-paint your grille
2. Replace with a chrome/gray OEM grille
3. Select an aftermarket grille that meets your "blackout" requirement
HTH
HTH
Thank you!
Hello! First post so please bear with me. I'm looking for the part numbers for the two interior trim pieces labeled here. I've looked everywhere and can't seem to locate them. Thank you!
2010 Land Cruiser, my apologies!
No worries.. Actually, if you put it in your signature line it can streamline other help in the future if you need it.
For the requested part numbers.. Note that the padded knee area is a separate part. This is the silver solid plastic portion.
Left hand: 55403-60010-C0
Right hand: 55402-60010-C0
Thank you so much! Found them!
Wondering where I can finding the internal boxing for left side rear view mirror only? See picture
Thanks all.
“Lc200 2020
Thanks all.
“Lc200 2020
Appears it's only available as the whole mirror assembly minus the colored shell. Which means it'll be expensive.
Part number will depend on whether you have lane-change assist/rear cross-traffic alert..
Left hand, without cross-traffic: 87940-60R52
With cross-traffic: 87940-60R82
Pre-trip inspection find. It’s either “H” or “D”.
This may have been broken since I had modifications done before I took delivery but now that I’ve seen it I’ll obsess.
View attachment 3913283View attachment 3913284
These are pretty tough as the diagrams don't have a ton of resolution.. but my guess is 17366-0S010
Usually I'd confirm with a google image search but that isn't coming up with anything useful either. Fortunately they aren't too expensive to just grab one and see whether it's correct.
Cool, less than $10 so worth a shot, a zip tie can hold it in the meantime.
Thanks!
hi! looking for the lexus credit card key for my 2019 Toyota Land Cruiser. looks like it was sold in July of 19 but i dont know when it was manufactured. THANKS!
I don’t know much about these and it not being an official Toyota part I can’t just look it up.. sorry.
I will say you can get your build date from the vehicle info tag in the driver’s door jamb.
I am having some trouble locating the part number for the front caliper flange bolts for a 2021 LC. Last year when I did my brakes I used 90105-A0336 but the Toyota dealer website is saying that this isn't a match.
