maat
yeah nah maybe
one of these days i will pull my finger out
I was trying to figure out how you did that then realized RHD! Got me! Looks great.Looks good - I notice that you had to cut the entire grille at the lower end to accommodate the cooler.
Meanwhile I have tinkered quite a bit to get those first pipes bit from the turbo towards the cooler finished. After a bit of practise the tig welding went better than expected. Ok,
its not as consistent as if done by a experienced tig welder but absolutely fit for purpose I would say.
Interestingly I could not find any silicone joiner which fitted the 12HT 54 mm turbo outlet here in NZ - I eventually found one in Sweden while visiting Germany. I was quite sure that the many CT26 /CT20b turbos which are getting tinkered with would make this size a popular diameter. I fitted a direct step from 54 to 63 mm.
The 'S' is quite tight and took a good while to get right - in fact it is not touching anything despite looking so in the picture.
I'll replace the second / blue silicone joiner from the turbo with a weld in the end and trim the last silicone joiner connecting the intercooler - it looks horrible being in fact too long.
So next week end I'll hopefully get the outher side done.
I fitted a temperature gauge in the inlet just below the butterfly just for an before and after comparison and it's getting shockingly hot there !
Cruising at 80 km/h in ambient temperature of 26°C (80F) the charge air is about 60-70°C (140-158F) but on a bit of an incline or cruising at 110 km/h it gets quickly to 90°C (194F) and above - I haven't yet driven up a decent longer hill yet. So it is well worth the effort to do fit the I/C !
View attachment 3561708View attachment 3561710View attachment 3561712
Thanks!Looks good - I notice that you had to cut the entire grille at the lower end to accommodate the cooler.
